I agree with both Jonathan and Jazz
how ever cut3d is quite a crap program
I am doing a trial in MDF of the 3D model as I'm typing this reply
for my model I have chosen 10mm cut depth it did suggest 18mm on the scale but I chose 10 mm as I'm not after a deep cut
The model is 400x350x10mm.
I could chose to cut a silhouette cut out in cut3d but it left a big piece of material in the shape of a island near a shoulder so I've gone for a square cut out (in cut3d) you can't chose to cut a oval or round shame
I am doing a roughing pass with a 6mm single flute cutter and in cut3d this only allows you one cutter for this operation
so I'm in the roughing pass part of the program and after that the finishing pass program and then the cut out and then the preview the roughing pass has three passes at 3 mm and then one at 0.50 and then the finishing pass (two) at 45 degrees to the rough cuts
and then I have chosen to do a cut out but I will stop it at 11 mm
cut3d is quite limited as the only tools you have is the ones with in the set stages and that's it.
The CNC machine is cutting on pass three and is at a depth of 9 mm the finishing cutter is only a 6 mm ball as that's the smallest ball cutter I have a the moment
and as I said it's only a MDF test, I'm waiting for my Oak timber to arrive so I can glue it up plane it and start making the coffee table
I plan to have the model carved into the legs as well (on two different plains) but we will see how a test goes first
James
Aluminium Extrusion Supplier
By adamh in forum Marketplace DiscussionReplies: 2Last Post: 06-12-2013, 07:52 PM -
1.5mm Mill End Cutter Can Anyone Recommend a Supplier
By Ridgeback in forum Milling Machines, Builds & ConversionsReplies: 6Last Post: 25-01-2013, 12:53 AM -
Where to buy long ball nose mill for foam cutting?
By jamezwarner in forum Marketplace DiscussionReplies: 5Last Post: 10-05-2012, 02:03 PM -
UK Tooling Supplier
By audioandy in forum General DiscussionReplies: 1Last Post: 13-07-2010, 03:25 PM -
Who is the best online ball screw supplier and stepper motor selection
By NICKMODELMAKER in forum General DiscussionReplies: 9Last Post: 14-03-2010, 04:04 AM
