26-01-2012 #11
Yes Dean it will be more than up to cutting wood.! . . . . There are issue's which arn't Ideal like easy setup of parallel rails like Jonathan touched upon. . . But if like I said with carefull selection of material they will be very close and then It's not difficult to manipulate them parallel with filling/grinding and spacers/shims.
My experinece with Cheap chinese round rail is that it's not straight or consistant in dimesions along it's length, just as the bearings mounting surfaces are rarely level, flat or true so shimming is nearly always required to fine tune. . . BUT AGAIN . . . It's down to intended use and for machineing wood then the tolerences are much lower and forgiving so can be tolerated.
If you want to wear belt & braces (excuse the PUN!!) and just add some bracing along it's length.!!
Regards that Pic you posted I'm pritty I've seen that before and it was actually built to cut stone.?? . . . . But don't quote on that!!. . . . But I've certainly seen one built the same that was cutting stone and it actually came up for sale on Ebay.
Plasma Attempt #2
By Robin Hewitt in forum DIY Plasma Build LogsReplies: 21Last Post: 02-09-2012, 08:05 PM -
BUILD LOG: My first attempt.... 8 x 4
By trounce in forum DIY Router Build LogsReplies: 0Last Post: 18-10-2011, 11:31 AM -
BUILD LOG: My First Attempt Of A CNC
By AdCNC in forum DIY Router Build LogsReplies: 61Last Post: 21-10-2010, 03:55 PM -
help please with first attempt
By phill05 in forum Machine DiscussionReplies: 13Last Post: 01-06-2010, 05:42 PM -
FeatureCam - first attempt
By HiltonSteve in forum CAD & CAM SoftwareReplies: 0Last Post: 01-09-2009, 07:46 PM
