    Ok, i think i'm finally getting there. All plate is 20mm thick ali and also using I-beams. I'm not sure if the screw mounts are ok doing it this way. Would the bearing blocks need spreading out more. All the rails are 20mm with 1610 screws. Some pictures to show my progress and please tell me where i have gone wrong and where improvement can be madeClick image for larger version.
Name:	front view-final.jpg
ID:	6471Click image for larger version.
Name:	back view-final.jpg
ID:	6472Click image for larger version.
Name:	z axis view.jpg
ID:	6473Click image for larger version.
Name:	1450mm ballscrew.jpg
ID:	6474Click image for larger version.
Name:	800mm ballscrerw.jpg
    I will have the ballscrew end machining increased from 15 to 30mm as i want to use belts and pulleys.
    The RSJ's are 178x102x19mm, would it be better to use a smaller size on the gantry, 127x76x13mm.
    Also just realised i haven't taken into account the thickness of the beams
  1. Plasma Attempt #2
    By Robin Hewitt in forum DIY Plasma Build Logs
    Last Post: 02-09-2012, 08:05 PM
  2. BUILD LOG: My first attempt.... 8 x 4
    By trounce in forum DIY Router Build Logs
    Last Post: 18-10-2011, 11:31 AM
  3. BUILD LOG: My First Attempt Of A CNC
    By AdCNC in forum DIY Router Build Logs
    Last Post: 21-10-2010, 03:55 PM
  4. help please with first attempt
    By phill05 in forum Machine Discussion
    Last Post: 01-06-2010, 05:42 PM
  5. FeatureCam - first attempt
    By HiltonSteve in forum CAD & CAM Software
    Last Post: 01-09-2009, 07:46 PM
