    Hopefully this will work. I hoping to have the Y axis 1500mm long and the x 850mm, this will help with the space i have available and will make it easy with placing the work material. i have 16mm rails,16mm screw on the x. 20mm screw and 25mm rails on the Y axis and i was thinking 16mm screw and 16mm rails on the x axis. This will sit on a steel box section frame. Have i got it right or wrong:confused:. Also going to use belts and pulleys, that's 45x 45 ali profile and 20mm ali plate as well
Name:	almost complete a.jpg
ID:	5258   Click image for larger version.
Name:	almost complete b.jpg
  1. Plasma Attempt #2
    By Robin Hewitt in forum DIY Plasma Build Logs
    Last Post: 02-09-2012, 08:05 PM
  2. BUILD LOG: My first attempt.... 8 x 4
    By trounce in forum DIY Router Build Logs
    Last Post: 18-10-2011, 11:31 AM
  3. BUILD LOG: My First Attempt Of A CNC
    By AdCNC in forum DIY Router Build Logs
    Last Post: 21-10-2010, 03:55 PM
  4. help please with first attempt
    By phill05 in forum Machine Discussion
    Last Post: 01-06-2010, 05:42 PM
  5. FeatureCam - first attempt
    By HiltonSteve in forum CAD & CAM Software
    Last Post: 01-09-2009, 07:46 PM
