Jazz,
I found this on cnczone and reading his posts i think you are correct and it was used for cutting stone, he was in Indonesia. If i chose the earlier option of 2 box sections sandwiched between plate, would it be ok to use 10mm plate and use 20mm on the Z axis only. Just want to weight up all the options at the moment.
Just out of interest, i'm looking at using 1605 and 2005 ball screws, belts and pulleys if possible. I had a go at the weekend cutting the infamous Aztec/Mayan calendar, approx 12" size, after 3 hours i had cut less than a 1/5th. How much faster roughly would using ball screws make a difference.Last edited by deannos; 26-01-2012 at 03:35 PM.
26-01-2012 #2
20mm is a good size plate for the Z-axis.
The efficiency of ballscrews is roughly twice that of ACME screws, so it will be significantly faster. For the Aztec calender acceleration is much more important as it's lots of tiny moves. The bearing nut thingy you're using will make the difference slightly less. The main advantage is 5mm pitch versus 2mm pitch - the kinetic energy in the screw is significantly less if it's rotating 2.5 times slower.
The most accurate comparison you're going to get is comparing with my machine, as I sold you the screw. I got 6m/min with the screw your using and 42:13 pulleys on Y. I ran it at less than that with smaller pulleys as that was too close to the critical speed of the screw (see my build log for actual values). With 42:14 (I think) and a 10mm pitch ballscrew I got 60m/min. That's much more than you'll ever need so I've left it on close to 1:1 to get better resolution and acceleration.
26-01-2012 #3
Plasma Attempt #2
By Robin Hewitt in forum DIY Plasma Build LogsReplies: 21Last Post: 02-09-2012, 08:05 PM -
BUILD LOG: My first attempt.... 8 x 4
By trounce in forum DIY Router Build LogsReplies: 0Last Post: 18-10-2011, 11:31 AM -
BUILD LOG: My First Attempt Of A CNC
By AdCNC in forum DIY Router Build LogsReplies: 61Last Post: 21-10-2010, 03:55 PM -
help please with first attempt
By phill05 in forum Machine DiscussionReplies: 13Last Post: 01-06-2010, 05:42 PM -
FeatureCam - first attempt
By HiltonSteve in forum CAD & CAM SoftwareReplies: 0Last Post: 01-09-2009, 07:46 PM
