27-01-2012 #11
The best position for the Y-axis ballscrew is between the Y-axis rails so that there can be no movement of the linear bearings without the ballnut moving. More precisely the ballscrew should lie on the plane occupied by both the Y-axis rails, parallel to the rails. With the RSJ design it's close enough, with the previous design using two 80x40 box sections and 10mm plate it would be perfect.
(meant to post this in the previous post)
As long as you use RM1610 ballscrews to move the gantry it will still be fast due to the higher pitch and more importantly get better acceleration than RM1605. You'll want a 1:1 ratio with 10mm pitch, but I used pulleys anyway to reduce resonance. You can always swap the pulleys round to get a 1:2 ratio for better resolution. If you get the end machining for the ballscrew where the pulley mounts made 8mm, same as the motors, instead of 10mm then swapping the pulleys is simple. For instance use two 15T on Y and 30T on X you can swap them all round to get 15:30 if required.
Also I got the end machining for the pulley made 25mm long instead of 15mm as it makes it much easier to align and mount the pulleys.
RM1605 may still be fast enough, but when you're getting them from linearmotionbearings2008 on eBay I don't think there's much if any difference in price between the two so no point. Especially since you can use pulleys to get effectively the same pitch (if required, for the vast majority of things it wont be) as RM1605 with better v&a as the screw is only spinning half as fast.
Plasma Attempt #2
By Robin Hewitt in forum DIY Plasma Build LogsReplies: 21Last Post: 02-09-2012, 08:05 PM -
BUILD LOG: My first attempt.... 8 x 4
By trounce in forum DIY Router Build LogsReplies: 0Last Post: 18-10-2011, 11:31 AM -
BUILD LOG: My First Attempt Of A CNC
By AdCNC in forum DIY Router Build LogsReplies: 61Last Post: 21-10-2010, 03:55 PM -
help please with first attempt
By phill05 in forum Machine DiscussionReplies: 13Last Post: 01-06-2010, 05:42 PM -
FeatureCam - first attempt
By HiltonSteve in forum CAD & CAM SoftwareReplies: 0Last Post: 01-09-2009, 07:46 PM
