28-01-2012 #10
Here's a bit of food for thought for ya.!!! . . . . Why not build 2 small concrete block walls with a plate securely bolted down onto it. Then with adjustment jack nut n bolts thru both to level the RSJ's. Then you could just push a strong bench under neath fasten down then surface it flat and away you go with virtually no material height restriction.
Obviosly you will have Z axis travel restriction but not material height.!!. . . The machine use's and flexibilty regards material sizing become far greater.!!. . . . Imagine some one wanting an old table surfacing or V carving. . . . how easy does that become.? . Ye I know not probable but you get the idea.
The same plate/jack system would work good on a bench thou.
Some time towards the end of the year I'll be building just such a machine that use's R&P and will be used for cutting granite slabs 3x2mtr into work surfaces. This will use the same principle but have a free standing concrete table with a hydrolic tilting frame for loading slabs from near vertical to horizontal.
Plasma Attempt #2
By Robin Hewitt in forum DIY Plasma Build LogsReplies: 21Last Post: 02-09-2012, 08:05 PM -
BUILD LOG: My first attempt.... 8 x 4
By trounce in forum DIY Router Build LogsReplies: 0Last Post: 18-10-2011, 11:31 AM -
BUILD LOG: My First Attempt Of A CNC
By AdCNC in forum DIY Router Build LogsReplies: 61Last Post: 21-10-2010, 03:55 PM -
help please with first attempt
By phill05 in forum Machine DiscussionReplies: 13Last Post: 01-06-2010, 05:42 PM -
FeatureCam - first attempt
By HiltonSteve in forum CAD & CAM SoftwareReplies: 0Last Post: 01-09-2009, 07:46 PM
