I was thinking steel box section, but aluminium extrusion is pretty good too. If you're happy to do some welding then steel box section is the cheapest and strongest option for making a frame. The standard length is 7.5m, so it would be prudent to design the frame to use an integer multiple of 7.5m! I used 60x60mm, 3mm wall thickness box section for most of the frame and 100x60mm, 3.6mm wall thickness for the two lengths the X-axis rails mount on.
How long is the piece of RSJ you've drawn for the gantry?
I always call the axes on the gantry Y and Z and the other axis X. So by that definition in your case X is shorter than Y.
The what.. never seen that! I just copy and paste the [QUOTE] tags in the relevant locations. I've put them in on your post for you, so if you click 'Edit Post' you can see how...
02-08-2012 #2
Plasma Attempt #2
By Robin Hewitt in forum DIY Plasma Build LogsReplies: 21Last Post: 02-09-2012, 08:05 PM -
BUILD LOG: My first attempt.... 8 x 4
By trounce in forum DIY Router Build LogsReplies: 0Last Post: 18-10-2011, 11:31 AM -
BUILD LOG: My First Attempt Of A CNC
By AdCNC in forum DIY Router Build LogsReplies: 61Last Post: 21-10-2010, 03:55 PM -
help please with first attempt
By phill05 in forum Machine DiscussionReplies: 13Last Post: 01-06-2010, 05:42 PM -
FeatureCam - first attempt
By HiltonSteve in forum CAD & CAM SoftwareReplies: 0Last Post: 01-09-2009, 07:46 PM
