Thread: calibration
No, you measure the distance travelled. But we can't ever measure it with zero tolerance, so it will always be slightly out. For most people that doesn't matter, but that doesn't make it all-right in my opinion.
Definitely not true. The only way the diameters could be different is if the number of teeth is different. If you look at the tolerances for the pulleys it's not possible for such a large error. Also having made several pulleys it's obvious that if you get the diameter out by the smallest amount the belt simply doesn't mesh with the pulley, so if the diameter was wrong the pulley wouldn't work.
James did you count both pulleys on Y and Z? It just seems too big a co-incidence that the number is so very close to making it 28T.
11-02-2012 #2
Ok "Boy wonder" your the "Man" for calc's All I know is how to make it work correct.! :dance:
Calibration issues, advice needed
By Kernow Jim in forum Motor Drivers & ControllersReplies: 16Last Post: 23-01-2014, 07:18 PM -
Problem with calibration
By m.marino in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 22-04-2010, 04:19 PM -
Chronoscope Calibration Tool
By Robin Hewitt in forum General ElectronicsReplies: 1Last Post: 29-11-2008, 01:26 AM
