27-01-2012 #2
Thanks Philly, does it come with any software?
06-10-2013 #3
Hi
I'm new to the forum and to CNC. I've just taken delivery of a rather battered CNC3040. Can you tell me if it is normal for the X and Y axis motors to be very stiff to turn by hand. The Z is quite free. I've powered it all up and Z runs fine. The other 2 motors just make a humming noise. I've reconfigured the pins to drive X with known good channel Z but it still won't run. Do I suspect motors, wiring or warped drive chain. I will attempt to get a replacement but am not holding my breath.
Any guidance appreciated.
thanks
John
07-10-2013 #4
Wouldn't bother with replacement try for a refund and get or build something better.!!
Sounds very much like you have mechanical problems rather than Electrical if other Axis won't move when connected to Z axis drive. Very much doubt it will be dead stepper they are sturdy things and the fact you have 2 non moving Axis makes me think Mechanical.
So I'd start by removing the motors from screws and checking if they spin on there own drives with no load.?
Then work back from there removing ballnuts from the mounts first and spinning screws to see if end bearings are binding or the ballnut it's self has jammed.
It will become obvious whats causing the problem when motors are off.!!
07-10-2013 #5
Ballnuts! 1404 trapezoidal screws
I guessing they might be a wee bit stiff to turn by hand anyway.
07-10-2013 #6
Ye I knew chances are they would have Trap lead screws but easier to say ballscrew and ballnut has if new to cnc they would probably recognise those terms better than saying Leadnut etc .!! . . . . . . But in any case they should still turn by hand easy enough if Trap Lead screws.
07-10-2013 #7
Hi thanks for the response. My hobbies are woodturning and electronics, with very little mechanical experience. Hence building one is a bit daunting. I did as you suggested and removed the motors. The X motor didn't run but then after re-installing it, it did. Wiring? The Y axis motor (disconnected from drive) would not run at all on any pins, obviously faulty. Is it normal for there to be lateral movement, maybe 2mm when I pull along the X axis by hand.
thanks again
John
PS have asked for refund.
07-10-2013 #8
Yes quite normal if it's Knackerd.!! . . . .Which by the sounds then it is.!
There should be NO lateral movement or Slop in any direction on any Axis. You will never cut correctly or with any accuracy if there's movement in any direction. Circles will be Ovals, edges will have steps at start and finish points and generally rubbish finish quality and poor accuracy.
. . Honestly Push hard for the Refund.
Chinese Nema 34 packages on ebay
By adamh in forum Marketplace DiscussionReplies: 4Last Post: 06-12-2013, 12:24 PM -
Chinese CNC machines - Request
By craigrobbo in forum Milling Machines, Builds & ConversionsReplies: 11Last Post: 03-05-2012, 05:55 PM -
NEW MEMBER: Just purchased Hardinge HL TFB tucson arizona usa
By jimbocafe in forum New Member IntroductionsReplies: 1Last Post: 19-12-2010, 02:45 PM -
Used Routout CNC Recently?
By CraftyGeek in forum General DiscussionReplies: 1Last Post: 17-07-2010, 12:37 PM -
Purchased a Taig CNC Micromill from Ebay
By alan2525 in forum Marketplace DiscussionReplies: 10Last Post: 16-04-2010, 10:53 AM
