21-02-2012 #71
OK..had a chance to investigate further but not resolved yet....been able to confirm that its a cable problem but unable to track down where exactly. Have to try and keep it going for the moment because we need the parts lol.
Checked out the control box internal wiring which appeared ok...no loose wiring etc and everything solidly bolted down.
22-02-2012 #72
Sorry i missed your offer to come and sort us out Jonathan, lol, much appreciated mate!
At the moment we are able to run ok on approx 50% of the bed without problems which enables us to continue and produce parts (for the moment anyway!)
In the meantime I will make up a new cable if i can work out what the connectors are!
22-02-2012 #73
24-02-2012 #74
Thanks for the suggestion Phil!
I made up a new cable this evening and although i havnt tested it in anger yet, the z axis does seem to work ok while moving the gantry back and forth.
Hopefully problem solved!!
24-02-2012 #75
Bugger me my machine went and did this yesterday.!! . . . I've just transfered all my control box into a new larger box. . . . I knew straight away what it was and to be honest I'm embaressed that I didn't think about it in your case.
It's one of the Dir pin wires thats either come out at drive or connection/wire come lose in motor. To be honest I didn't expect it to behave how it did.? I expected it would only move in one direction but it infact it was moving in one direction then changed direction randomly.!!
24-02-2012 #76
LOL , its catching, must be a virus going round!
Anyways were back up and running ok after replacing the cable...must have been a spot somewhere along the length of the cable where there was a breakage but making contact depending on where the gantry was positioned.
Thanks once again for all your input its been very helpful and much appreciated as usual!
24-02-2012 #77
Ho Hum...now what?...the spindle motor brushes have worn out!! After approx 6hrs intermittent running!!
Plus the remains of one have dropped inside the motor..lol..
So the saga continues....
24-02-2012 #78
Should still be under warrenty shouldn't it.?? . . Or is that has much use as the spindle.!!
24-02-2012 #79
Got a single speed Kress here if you are stuck and a mounting.
John S -
24-02-2012 #80
Thanks for the offer John, not had a chance to take this piece of crap apart yet to see if its recoverable...will do so tomorrow and decide what's best way forward.
Edit: Stripped it down and cleaned out gunge and brush/spring remmants etc.
Bottom bearing dosnt feel right but will run it later to test.
Ran it but its eating the brushes and sounds terrible...probaly bearing problems..Last edited by camhguh; 27-02-2012 at 11:02 PM. Reason: update
Chinese Nema 34 packages on ebay
By adamh in forum Marketplace DiscussionReplies: 4Last Post: 06-12-2013, 12:24 PM -
Chinese CNC machines - Request
By craigrobbo in forum Milling Machines, Builds & ConversionsReplies: 11Last Post: 03-05-2012, 05:55 PM -
NEW MEMBER: Just purchased Hardinge HL TFB tucson arizona usa
By jimbocafe in forum New Member IntroductionsReplies: 1Last Post: 19-12-2010, 02:45 PM -
Used Routout CNC Recently?
By CraftyGeek in forum General DiscussionReplies: 1Last Post: 17-07-2010, 12:37 PM -
Purchased a Taig CNC Micromill from Ebay
By alan2525 in forum Marketplace DiscussionReplies: 10Last Post: 16-04-2010, 10:53 AM
