Thanks to another member purchased a spare TB IC in the post.
Easiest to remove them by snipping all the pins off the chip , then mop up the solder and pins off the PCB.
Mounting new IC is straightforward, it clips over the board and holds itself inplace whilst soldering.
Unfortunately in this case , didn`t entirely solve the problem, Z fine going down, stalls and whines going up, hmmm
Transfer to Y axis , whines, lack of power.
PCB back under the magnifier, toasted thin ground track from what looks like 1R0 current sense resistor, put wire in from nearest pad to ground pin.
Result, fully working Z axis driver board.
Just one wiring anomoly now, must have reversed ppahses because motor is runnig reversed, up is down and down is up, do I have to get the soldering iron out again or can I reverse it in Mach3?
Adam
P.S. Also contacted vendor, who has asked for a picture of the damaged board so that they can send me out the right spare part under warranty, have just repaired in meantime to keep running.
02-03-2012 #2
12-03-2012 #3
Before I forget yet again, a public thank you to JohnS for the loan of a single speed Kress (he also machined up a collar to make it fit inside the original motor clamp) allowing us to carry on machining!
12-03-2012 #4
15-05-2012 #5
Sorry to jump in on this thread but i have the 3040 mill how did your machine handle the extra weight of the kress???
becouse i have the small 0.4kW (0.54HP) arc eurotrade highspeed spindle i`m thinking of fitting to mine
Chinese Nema 34 packages on ebay
By adamh in forum Marketplace DiscussionReplies: 4Last Post: 06-12-2013, 12:24 PM -
Chinese CNC machines - Request
By craigrobbo in forum Milling Machines, Builds & ConversionsReplies: 11Last Post: 03-05-2012, 05:55 PM -
NEW MEMBER: Just purchased Hardinge HL TFB tucson arizona usa
By jimbocafe in forum New Member IntroductionsReplies: 1Last Post: 19-12-2010, 02:45 PM -
Used Routout CNC Recently?
By CraftyGeek in forum General DiscussionReplies: 1Last Post: 17-07-2010, 12:37 PM -
Purchased a Taig CNC Micromill from Ebay
By alan2525 in forum Marketplace DiscussionReplies: 10Last Post: 16-04-2010, 10:53 AM
