27-02-2012 #16
The Z axis wiring fracture is contagious, mine is just exhibiting identical symptoms.
There`s a cheep Chinese mill FAQ to be started here....
Current small Chinese mill FAQ thoughts ;-)
Out of the box;
Check the connections inside the control box.
( had E-Stop button connected to limit switch header on parallel breakout)
Check the bolts on the frame for loose or stripped threads.
(Stripped thread on carriage bolt, worked loose, no problem space to put bolt in place)
Check the life left on spindle brushes.
(couple of premature spindle failures reported)
Make up 4 core stepper driver and 2 core screened loom for Z- axis and spindle for when the original fails.
(early failures reported)
AdamLast edited by Musht; 27-02-2012 at 10:33 PM.
Chinese Nema 34 packages on ebay
By adamh in forum Marketplace DiscussionReplies: 4Last Post: 06-12-2013, 12:24 PM -
Chinese CNC machines - Request
By craigrobbo in forum Milling Machines, Builds & ConversionsReplies: 11Last Post: 03-05-2012, 05:55 PM -
NEW MEMBER: Just purchased Hardinge HL TFB tucson arizona usa
By jimbocafe in forum New Member IntroductionsReplies: 1Last Post: 19-12-2010, 02:45 PM -
Used Routout CNC Recently?
By CraftyGeek in forum General DiscussionReplies: 1Last Post: 17-07-2010, 12:37 PM -
Purchased a Taig CNC Micromill from Ebay
By alan2525 in forum Marketplace DiscussionReplies: 10Last Post: 16-04-2010, 10:53 AM
