Thread: 1 axis tb6560 any good?
	06-08-2012 #11Yeah. I hope this one's going to be OK too.
 This one seems to repeat the error of deriving the 5v supply from the motor supply. It appears the TB6560AHQ is easily smoked if the motor voltage is applied before the 5v has settled or removed before the 5v is removed.
 I suspect the design may be using the optos connected active low to alleviate their slew rate problems rather than using a Schmitt Trigger. At this stage it seems the I/P and driver are completely opto-isolated.
 More to follow after I get some juice on it.Last edited by boldford; 06-08-2012 at 06:27 PM.
	06-08-2012 #12Hi John,
 If you have the source code for the arduino, I could mod it for you. If not I would need to know what the Little Bugger does and I would have some idea how long I would need to code and test from scratch. I have three Arduinos of varying strengths sitting a box and the arduino community has a lot of code and functions available. Give me a call in a week if you wish to discuss. At the mo I have a bloody awful cough and cold and feel as rough as a badger's arse.
 Cheers Rob
 PM me if you need my phone number.
	07-08-2012 #13Rob,
 The guy was able to invert the signal and get the driver working. Works OK but a lot of noise from the driver, very much like the cheap 3 axis board I have in my small engraver.
 Been running the application using this single axis TB driver, one of Roy's System3 drivers and a 542 driver.
 No contest, the 542 is head and shoulders above the other twoJohn S -
	07-08-2012 #14
	07-08-2012 #15
 Thats because the m542 has proper sinusoidal current control and not a chopper controller, the result being less harmonics and less noise (mechanical and electrical). I don't know what you pay for them John (probably less than most of us) but at £28-ish each in set of 4 off eBay its only a tenner or less more than the TB solution and well worth that difference...
	08-08-2012 #16Having begun my investigation I must give my first words of warning. This tip may apply to any of these monolithic drivers from any vendor; domestic or overseas.
 To check out the reverse side of the board it was necessary to remove it from the (reasonably proportioned) heatsink. Unfortunately I found just the barest smear of heat conductive compound where the TB6560 is fixed to the heatsink. I would recommend anyone buying ready made drive units to check this and, if necessary, apply enough to get maximum thermal bonding. The thermal compound costs pennies yet might save you pounds and all the hassle of down-time.
  tb6560By uppy121 in forum Motor Drivers & ControllersReplies: 7Last Post: 08-04-2013, 10:39 AM
  problem: y-axis only moves in one direction using TB6560 board off emailBy polysoul in forum Machine DiscussionReplies: 9Last Post: 08-06-2012, 12:12 PM
  4 Axis TB6560 CNC Driver For NEMA17/23/34 Motor 3A on Ebay update.By TommeyReed in forum Motor Drivers & ControllersReplies: 2Last Post: 06-03-2012, 06:01 PM
  TB6560 Motor MatchBy Telly in forum Motor Drivers & ControllersReplies: 10Last Post: 22-02-2011, 06:29 PM
  FOR SALE: 4 Axis TB6560 Stepper Motor Driver BoardBy Mad Professor in forum Items For SaleReplies: 1Last Post: 04-01-2011, 06:54 PM
