Thread: 1 axis tb6560 any good?
I've looked at then and was hoping someone here had tried them. The 3 axis ones seem to be a nightmare. For low current application I'm toying with trying http://www.hobbytronics.co.uk/pololu...r-motor-driver or http://proto-pic.co.uk/big-easy-stepper-motor-driver/ with a possible addition of opto-isolation.
Any thoughts folks?
08-07-2012 #2
The Allegro driver boards are widely used with Reprap 3D printers, they seem to have a good rep. I think a few people burn them due to miswiring or inadequate heat sinking.
AFAICT the problems with TB6560 are related to requiring a relatively slow pulse rate, and with modern controllers that can create fast pulses, you get missed steps. The Allegro drivers work down to 1us pulses, which should be fast enough for anything you can throw at them!
It would be good to find a 3/4 axis board with Allegro drivers, might be cheaper than buying separate modules.
08-07-2012 #3
I'm inclined to prefer separate driver boards for each axis. If one does suffer a premature demise its far cheaper to change out the single module; moreover it may be easier to trouble-shoot by swapping modules around. Has anyone tried these http://www.quasarelectronics.com/315...tor-driver.htm 5 amps max makes them seem quite attractive; and a UK distributor.
08-07-2012 #4
If they did micro-stepping that wouldn't be too bad...if you're keen you could attach a PIC to it and program that to do microstepping (pretty easy to code), but by the time you've done that you might as well make the whole driver, especially since they've released the schematic. Athough that leaves a bit to be desired - back-emf diodes for instance!
For a few £ more though:
http://www.ebay.co.uk/itm/CNC-Micro-...ht_7002wt_1270
You're unlikely to need more than 4.2A since most Nema 23/24 motors fall in that range when wired in bipolar parallel.
tb6560
By uppy121 in forum Motor Drivers & ControllersReplies: 7Last Post: 08-04-2013, 10:39 AM -
problem: y-axis only moves in one direction using TB6560 board off email
By polysoul in forum Machine DiscussionReplies: 9Last Post: 08-06-2012, 12:12 PM -
4 Axis TB6560 CNC Driver For NEMA17/23/34 Motor 3A on Ebay update.
By TommeyReed in forum Motor Drivers & ControllersReplies: 2Last Post: 06-03-2012, 06:01 PM -
TB6560 Motor Match
By Telly in forum Motor Drivers & ControllersReplies: 10Last Post: 22-02-2011, 06:29 PM -
FOR SALE: 4 Axis TB6560 Stepper Motor Driver Board
By Mad Professor in forum Items For SaleReplies: 1Last Post: 04-01-2011, 06:54 PM
