    Okay Jonathan you can take your genius hat off for a moment. Mach 3 running and still no joy. The freemill forum say that it probably is lack of permission to save data where it wants to . I have tried to change the permissions on the fremill folder but it keeps stopping me. Not to worry I will now have a play with the mach3.
    Regards
    Bruce
    BTW 1st of the ally arrived today.
    The more I know, I know, I know the less. (John Owen)
    Quote Originally Posted by motoxy View Post
    That's not quite what I meant. I meant if the if mach3 is running with that file open any program can't write to it.
    Have you tried saving to a different folder, or if that's not possible and it just defaults to the freemill directory then move freemill to somewhere you definitely have permission such as my documents.
    Btw to play with mach3 if you installed the parallel port driver you'll need to disable the Estop. If you tick the active low box for Estop in config->ports and pins->input signals that will invert the input so mach3 'thinks' the Estop is not activated and lets you play...
  1. Problem with X
    By gorbo in forum General Discussion
    Last Post: 24-02-2011, 05:33 AM
  2. Problem with calibration
    By m.marino in forum Gantry/Router Machines & Building
    Last Post: 22-04-2010, 04:19 PM
  3. NEW MEMBER: New with a threading problem
    By GeoffS in forum New Member Introductions
    Last Post: 02-12-2009, 09:23 PM
  4. Z Problem
    By airwolf in forum Machine Discussion
    Last Post: 10-11-2009, 08:08 AM
  5. FreeMill
    By Smiler in forum Computer Software
    Last Post: 21-05-2009, 10:45 AM
