    Thanks for all the info Tom, it seems you are a mine of information!
    I'm new to both the leather and the metal side of things so it's a very steep learning curve for me here. The help is very much appreciated.
    I've got neither the tools nor the skill to make these things myself, thankfully one of the members on here has offered to make a sample for me. I think the design will work, not sure exactly on how to attach it yet though.
    The leather of the bag is quite heavy nubuck, and the handle is actually going to loop back so it's doubled as it goes through this metal piece. Plan b if I can't get these metal parts was to slot cut the bag face like you suggested and just use stitching. I imagine the solution will be doing the same but with the screws giving the main support.
    I seem to be waffling with no real point here... My head is spinning from all the options :)
    Quote Originally Posted by barryg View Post
    When you get a sample in your hand you'll get a much better perspective on the design. Hand bags can be difficult because girly's tend to fill em up, so they look good empty but bad when full. Nubuck should be quite tough but just think a little about taking the stresses out of that handle/bag joint, you could run it inside around the base for some extra strength and the actual joint becomes almost cosmetic. Learning is good! And there's lots of help available.
    Tom
    Sherline lathe, Chester DB11V lathe, Myford/ Rodney mill, CNC mill Isel/ home made, Sealy Hack Saw, Meddings Pillar drill.
  1. DIN rail and fittings suppliers
    By Neale in forum Marketplace Discussion
    Last Post: 19-05-2014, 10:14 AM
  2. RFQ: I need apx 100 brass tubes being cut down
    By Chance1234 in forum Projects, Jobs & Requests
    Last Post: 02-04-2014, 02:05 PM
  3. FOR SALE: Various fasteners & fittings for aluminium profile
    By samiam5032 in forum Items For Sale
    Last Post: 27-02-2014, 07:53 PM
  4. RFQ: Brass tags
    By drumsticksplinter in forum Projects, Jobs & Requests
    Last Post: 23-06-2013, 06:17 PM
  5. SAE thread fittings Vacuum Pump
    By Bazzer in forum Marketplace Discussion
    Last Post: 27-05-2013, 12:02 AM
