    I have bought these larger powered 4nm's from Zapp, Roy at DIY - CNC and also from the link above and China direct. They are all interchangeable so all must be 23's unless i'm missing something here ?
    I can't see the 4nm motors at Zapp, only the standard 3nm that everyone sells.
    Also £600 for the enclosure doesn't sound high to me. These guys are working for a living, not pissing about in a garden shed and that stuff isn't cheap. I built two enclosures for the KX series machines to go in at the shows for ARC. I'll bet he wished I'd only charged him £600 quid a pop
    What I meant is I'd never recommend paying that much for an enclosure when it's something anyone can make. You don't really need to know anything about CNC to make an enclosure, as it's just a box. Plus if you're going to charge £600 for an enclosure why make it from extrusion when you get a bigger profit with other materials :lol:
    Sorry, brain fart meant the 3nm ones but both Gary's and Roys are in the fatter frame. So although they are fatter at 60mm and called type 24? the bolt fixings are still the same as type 23.
    John S -
  3. Oh and to simulate torque i coupled the motor to a larger nema 34 motor and shorted the windings.
    This works but its bloody noisy.
    Fair enough, I should have compared the power consumption. The ratings imply the power consumption is nearly equal which is inconsistent. I'll continue to steer clear of those motors...
  2. Strike CNC
    By GMCNC in forum Marketplace Discussion
    Last Post: 17-10-2012, 08:06 PM
  3. Your Opinion MK2 .. STRIKE CNC machine
    Last Post: 25-05-2012, 03:49 AM
  4. Strike CNC
    By Strike CNC in forum Manufacturer News
    Last Post: 15-02-2012, 10:35 PM
