    When the machine first arrived Strike helped me over the phone to setup and part of that involved changing some DIP switches on the drivers.
    Here's what I found in the control box on closer inspection.
    • 230v wires exposed out of the estop
    • 230v live wire sheathing damage potentially allowing for contact with the chassis
    • No chassis ground so if the above happened your going to get electrocuted
    • DC Wiring colour coding reversed in places and then in others its as you'd expect.
    I've attached images of these and informed Strike back in February when they came. The issue was side stepped and I took it upon myself to completely strip out the electronics and re-wire to a safe standard.
    Jimg100. Is this the sort of thing you saw on your machine?
ID:	6405   Click image for larger version.
ID:	6406   Click image for larger version.
  2. Strike CNC
    By GMCNC in forum Marketplace Discussion
    Last Post: 17-10-2012, 08:06 PM
  3. Your Opinion MK2 .. STRIKE CNC machine
    Last Post: 25-05-2012, 03:49 AM
  4. Strike CNC
    By Strike CNC in forum Manufacturer News
    Last Post: 15-02-2012, 10:35 PM
