    I bought a strike CNC balls up this year, it too was a month+ late and had all the above faults and more. It was supposed to have traverse speeds of 6m/min+ but Michael Powel advised that 6 would be best, to date I can only run at 2m/min. I went through the control cabinet and reconnected all the wires as they had been stripped too far and were also all loose one fell out of the emergency stop switch.
    Is Strike still going or have they gone bust as they are'nt answering any cals or emails?
    Quote Originally Posted by jimg100 View Post
    Sorry to hear of that Jim. Its a horrible feeling isn't it.
    I assume Strike CNC are still active because I had an email from them saying they were taking legal action against me for the contents of this thread.
    My advice is to do what I did and contact Trading Standards giving them a full and detailed report of situation your in and the faults with the machine. If you believe it was dangerous tell them that too and why. Even better if you have photographs.
    Here's the details for trading standards and citizens advice along with the telephone number for both. You might be better off finding your local trading standards office and calling them, I did this.
    http://www.tradingstandards.gov.uk/advice/index.cfm
    http://www.adviceguide.org.uk/
    08454 04 05 06
    Good luck and keep us updated.
    If he does take legal action it will be good as it will be at his cost and if we stand together there is no way he can win, we may even get some money back or our machines sorted.I am just putting my X axis back with new SKF bearings as the 4 supplied gave up the ghost.
    I have kept all my emails from him and have taken pictures of all the poor machining including the mods I have had to do to achieve a 150mm Z axis.
    Quote Originally Posted by Shinobiwan View Post
    08454 04 05 06
    When the machine first arrived Strike helped me over the phone to setup and part of that involved changing some DIP switches on the drivers.
    Here's what I found in the control box on closer inspection.
    • 230v wires exposed out of the estop
    • 230v live wire sheathing damage potentially allowing for contact with the chassis
    • No chassis ground so if the above happened your going to get electrocuted
    • DC Wiring colour coding reversed in places and then in others its as you'd expect.
    I've attached images of these and informed Strike back in February when they came. The issue was side stepped and I took it upon myself to completely strip out the electronics and re-wire to a safe standard.
    Jimg100. Is this the sort of thing you saw on your machine?
ID:	6405   Click image for larger version.
ID:	6406   Click image for larger version.
    Almost exactly the same all the wires going into those green plugs had been stripped to far and so there was approximately 6mm of bare copper with odd strands that were not clamped and so a possible short and several wire were not clamped tightly enough and I pulled them out easily.
    Is it ok to put my phone number on here as I would rather talk on the phone?
    You can PM me your number as I wouldn't recommend posting a phone number on a public forum.
    Or I can give you mine if that's easier.
  2. Strike CNC
    By GMCNC in forum Marketplace Discussion
    Last Post: 17-10-2012, 08:06 PM
  3. Your Opinion MK2 .. STRIKE CNC machine
    Last Post: 25-05-2012, 03:49 AM
  4. Strike CNC
    By Strike CNC in forum Manufacturer News
    Last Post: 15-02-2012, 10:35 PM
