Thread: Strike CNC (My first CNC router)
Have you tried another driver? is the problem with one driver?
is your version of windows 32 or 64 bit? did you do the tuning without any load on the motor shaft (Disconnected from the ballscrew?)
What is the motor? do you have the dasheet, and how are you connecting (Series or parallel) and what is the current set to?
These drivers are very good, and i personally use these drivers on my mill, and they are near silent and we only autotuned them.Visit Us: www.automationshop.co.uk
11-07-2012 #2
As with everything we sell, returns are accepted.
11-07-2012 #3
11-07-2012 #4
Set the current to either 3.6 or 4.6A, but start at 3.6A peak.
see if this solves the noise problem?
Regarding the software problem, this could be noise? make sure the RS232 cable is away from any power cables, and also make sure that your signal cables (Step, direction and enable) are well away from any power cables like the motor and the power supply cables. I cant see in the picture if you have done this. Also are the motor power cables shielded? and grounded at one end?Visit Us: www.automationshop.co.uk
11-07-2012 #5
Thanks for the help.
The stepper cables are shielded and ground at the control box end.
I'll try changing the current to what you suggest. The motors still made the same noise with the default setting of 1A before I changed it to 3.93A so no damage done to the motors.
Will play around some more this afternoon based on whst you've suggested.
11-07-2012 #6
OK, make sure that the rotary switch is in the "0" position.
Set the current to 3.6A and then power up.
Then move SW4 on and off twice to get the driver to tune to the motor specs.
Once this is done it should work ok.
Make sure the signal cables are not close to any power cables.
When you power the driers up, did the inverter for the spindle power up? if so disconnect it.
11-07-2012 #7
The noise is on all 4 steppers.
XP 32bit fresh install with only mach installedis your version of windows 32 or 64 bit?
A bit of both. 2 steppers (the Y and Z) are connect to the ballscrews and the dual steppers for the X are without.did you do the tuning without any load on the motor shaft (Disconnected from the ballscrew?)
What is the motor?
Nema 23 4Nm (8 lead type) on the X and Y. The Z is a Nema 23 3Nm.
Have the datasheet from your webshop.
Parallel wired and I've tried the current on the default (DIP 1,2,3=ON) and also 3.93A RMS (DIP 1 & 2=ON, 3=OFF)how are you connecting (Series or parallel) and what is the current set to?
11-07-2012 #8
They are not our motors, we dont sell 4Nm motors (Nema 24) if the current is 4A, then you need to set this to the peak value not the RMS.
if you are setting to 4A RMS, the motors will most likley burn out, and may be the cause of the excess noise?Visit Us: www.automationshop.co.uk
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM -
Strike CNC
By GMCNC in forum Marketplace DiscussionReplies: 1Last Post: 17-10-2012, 08:06 PM -
Your Opinion MK2 .. STRIKE CNC machine
By PWD in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 25-05-2012, 03:49 AM -
Strike CNC
By Strike CNC in forum Manufacturer NewsReplies: 0Last Post: 15-02-2012, 10:35 PM
