Unless everything is completely in line and mountings are square to the face then you could introduce binding or radial loads on the stepper.
Thermal conduction will not be a problem on a well designed system but interference will be.
You would be better off inserting a short stub into the end of the ball crew and use an Oldham coupling to join the screw to the motor. An Oldham coupling is the only coupling that can accept errors in two planes without imposing a radial force.John S -
06-02-2012 #2
The easiest way to mount a stepper is simply to bolt it on to shaft. Add a tie bar to stop the motor turning and let it wobble.
A couple of general design questions - ball-screw thread length, stub-shaft etc.
By Wal in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 02-01-2015, 08:32 AM -
FOR SALE: ArcEuroTrade 650Ncm 14mm Shaft stepper motor
By m_c in forum Items For SaleReplies: 0Last Post: 13-04-2014, 02:19 PM -
dc motor - spindle / shaft drive
By dsc in forum Spindles & Drive MotorsReplies: 21Last Post: 01-06-2013, 10:42 AM -
WANTED: stepper motor with dual shaft (6mm dia) wanted
By HankMcSpank in forum Items WantedReplies: 1Last Post: 08-04-2013, 12:48 AM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM
