hang it by the wires
06-02-2012 #2
I have at least 50 different tools which clamp into 30,000 rpm hand grinder collets with such concentric accuracy that side-to-side "run-out" inaccuracy is probably less than usual ball-screw bearing clearances. Why would we cut the shaft-retaining bore hole so inaccurately that run-out would cause interference problems at ballscrew rotation speeds? I have an air-driven dental drill that spins over 100,000 rpm, and its removable tools seem to stay pretty concentric with the motor's shaft. If they didn't, it would vibrate like crazy or self-destruct. Bore it accurately and forget it for these ballscrew spin rates.
Oldham couplings do impose radial forces on non-concentrically-connected shafts. That radial force is zero only at zero rpm, but it becomes positive as rpm increases from accelerating the non-concentric sliding coupler. If you're saying that at ballscrew spinning speeds, that radial force is trivial, I agree. But if you tried to couple two non-concentric shafts at hand grinder speed, that force would become objectionable.
John S said, "Thermal conduction will not be a problem on a well designed system . . ." Following motor manufacturer guidelines to determine limits to which you electrically load motors is one very conservative strategy. Prudent manufacturers rate their devices based on a distribution of usual expected environmental conditions. They leave some head room in those ratings so end users usually won't overheat motors they market. One big issue with permanent magnet motors is gradual flux loss from heating those magnets. That's why permanent-magnet-based position-sensor coil inductors fail so often in automotive applications. They are mounted in differential gearboxes generating pulses with every passing gear tooth, or in engines which swing iron parts past, inducing pulses in their coils with each swing. As these magnet's strength gradually degrades from heat-cool cycling, often before those vehicles reach 100,000 miles, one of those sensor's pulse strength drops below the threshold required to trigger the position sensing circuit. Similarly, permanent magnet based motor's performance can slowly degrade from heat-cool cycling. Any way you can reduce peak motor heating may extend that motor's original performance behavior. I'm not saying that rejecting motor heat through their shafts is a big deal, but it has value and dismissing that value because motor makers don't suggest it is your choice, not mine. I wonder why Emco attached radial fin heat sinks to some of their mill's stepper motors. Those motors didn't need those external heat sinks to comply with the motor maker's requirements. How hard you can safely drive any specific motor depends mainly on balancing heat generation against heat rejection.Last edited by LoveLearn; 07-02-2012 at 08:57 AM.
08-02-2012 #3
We would because the mounting tolerances required for a solid coupling are generally too high. Lack of concentricity places a cyclical load on the bearings and the load rating for that type of load on a bearing is significantly smaller. This is one of the numerous advantages of using a timing belt drive.
Tool is only supported on one end there, so different situation entirely.
Yes they do, but only due to friction between the sliding disk and aluminium end pieces. It will be negligible. Again if you're worried about radial forces use a timing belt as that applies a constant radial load which deep groove bearings tolerate better than cyclical loads. Still, that's analysing it too much . . much better reasons to use pulleys, such as matching the motor torque/rpm characteristic and resonance supression.
See here:
http://www.electricmotors.machinedes.../bdeee3_5.aspx
So the temperature rating is a threshold, which if you don't exceed that the magnets will not suffer permanent damage. The figure often quoted for stepper motors is 80°C case temperature, which is below the temperature rating of the magnets to account for the thermal resistance between the case and rotor.Ceramic or ferrite magnets lose about 0.13% / °C of their remanence above 25°C, while rare earth and AlNiCo may lose only 0.03% / °C. But this loss is generally reversible if the temperature is kept within the motor rating. Colder temperatures are seldom a problem. Since the coefficient curve is linear, magnets are stronger at lower temperatures.
That's thermal fatigue, which is a different problem not addressed by shaft heat rejection.
A heat sink on an expensive machine doesnt mean it's necessary, many machines add aesthetic and unnecessary features to appear expensive. The manufacturer's ultimate objective isn't a top notch machine but money. Also the motors to which you're referring are now obsolete - the design and materials have improved significantly since then so if heatsinks were required then, that does not imply they are required now.
As long as the motor is bolted to an aluminium mount I'm sure it will be fine, unless you're running them at a high voltage. Either way just make it, measure the temperature and think about adding heatsinks if you need to. My hottest motor (Z-axis) never goes above 50°C and that's just on 3mm thick mild steel.Last edited by Jonathan; 08-02-2012 at 02:10 AM.
A couple of general design questions - ball-screw thread length, stub-shaft etc.
By Wal in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 02-01-2015, 08:32 AM -
FOR SALE: ArcEuroTrade 650Ncm 14mm Shaft stepper motor
By m_c in forum Items For SaleReplies: 0Last Post: 13-04-2014, 02:19 PM -
dc motor - spindle / shaft drive
By dsc in forum Spindles & Drive MotorsReplies: 21Last Post: 01-06-2013, 10:42 AM -
WANTED: stepper motor with dual shaft (6mm dia) wanted
By HankMcSpank in forum Items WantedReplies: 1Last Post: 08-04-2013, 12:48 AM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM
