Thread: coolant
I'm getting braver and am thinking about cutting some brackets for limit switches next week but can I use 3 'n' 1 oil as a coolant or WD40 ??
James
11-02-2012 #2
3in 1 oil is too sticky WD40 works good on Ali. Any dewatering fluid will work good so buy the cheapist you can, WD40 is expensive.
11-02-2012 #3
Thank you Jazz
James
11-02-2012 #4
If you plan on doing lots of Ali cutting drop me aline because I sell a WD40 equivelent that's less than half the price. Only thing is I only sell it by the case 12x500ml aerosols.
11-02-2012 #5
Can make cheap alternative to WD40 with paraffin and some other stuff, google it.
The 'proper' coolant you see on all the youtube videos is oil diluted about 50:1 with tap water. I've got loads of it if you want a pint
http://www.rocol.com/corp/index.php?...244&Itemid=266 (for example).
Coolant, I am not sure which one to go with.
By suesi34e in forum Swarf & Chip ManagementReplies: 23Last Post: 17-10-2015, 07:13 PM -
Canola oil as a coolant ?
By cropwell in forum Swarf & Chip ManagementReplies: 9Last Post: 17-10-2015, 03:31 PM -
My Coolant System
By Tenson in forum Swarf & Chip ManagementReplies: 6Last Post: 08-04-2013, 01:59 PM -
What coolant to use??
By don_jarr in forum General DiscussionReplies: 13Last Post: 05-11-2011, 03:12 PM -
eBay: Castrol Cooledge Cutting Coolant Suds
By Lee Roberts in forum Items On eBay UKReplies: 3Last Post: 09-08-2009, 09:42 PM
