Thread: Z axis error woes
07-02-2012 #6
Yep, the PCB itself has good thickness tolerance so I was more thinking the PCB itself might not be stuck down flat, but as we both said... that makes no sense! Maybe the gantry slipped at one end? Again unlikely.
I doubt it's the USB cable as interference or interruption in the USB signal would cause all sorts of problems, not a nice linear error. Similarly if the motor is connected wrong it'll either break, not spin at all or spin the wrong way.
Out of the causes you suggested I think the acceleration setting is the most likely cause as that could well induce a consistent error. Testing on a different axis, or even probing a grid so we can plot a plane is also a good plan.
Try running the probing routine exactly as before, but twice in a row ... probe from Y0 to Y10, then start again at Y0. If the two point lists are virtually identical you know it's not a motor or motor tuning problem as those problems would make the second probing routine output different to the first.
Yep.
VFD error
By routercnc in forum Spindles & Drive MotorsReplies: 37Last Post: 21-06-2014, 08:40 PM -
huanyang vfd 2.2 error E.CO.A
By edgas10 in forum General ElectronicsReplies: 0Last Post: 01-07-2012, 08:12 PM -
Ballscrew Woes, help please!
By jonbabbz in forum Lead Screws, Nuts & SupportsReplies: 9Last Post: 21-04-2012, 12:16 AM -
Solidcam error
By Kai in forum SolidworksReplies: 5Last Post: 10-05-2011, 03:41 PM -
Warco Drawbar woes...
By irving2008 in forum Machine DiscussionReplies: 7Last Post: 22-12-2008, 12:56 AM
