Thread: Z axis error woes
08-02-2012 #31
Which bit?!! (there's nothing confirmed about the driver board - just an inkling only that it might be the problem ....it's certainly caused me no end of problems & googling reveals that A3977s should never be socketed blah blah). The significant part for me was that one remaining A3977 on my board is still fully working & therefoe allows microstepping, so yesterday I dropped that particular chip into my stepper board's Z axis position ....my probed errors became less (about 0.1mm vs 0.350mm over the same 10mm Y0->Y10 probing run ...now if it was mechanical or bed levelling, I reckon the error would be the same no matter what the resolution of the steppers.
I wasn't keeping this a secret - my 'post 11' on this thread yesterday alluded to this!
the thing is I'm likely to be coughing up for a better machine (which will come with very good stepper drivers), so just need to limp on investigating as best I can ...probably until the chap I'm buying off has more machines in stock (22nd feb)
oh...btw - All your jokes are falling ahem 'flat' :heehee:Last edited by HankMcSpank; 08-02-2012 at 11:38 PM.
08-02-2012 #32
LMAO . . .Can't come back at that one Poz. . :clap:
08-02-2012 #33
Hank what about just lifting the holders and soldering the QFP's directly to board?
Thanks Jazz at least it was us not STEPPING out of line here.......:naughty:.....My last one promiseIf the nagging gets really bad......Get a bigger shed:naughty:
08-02-2012 #34
08-02-2012 #35
Jazz your as bad as me not reading it all as well! Apologies to Hank:whistling:
08-02-2012 #36
09-02-2012 #37
Ok...solved!
It was my stepper board after all. This mnorning I managed to wire in a nasty Chinese TB6560 based stepper board (in place of my easy-cnc 3 axis board).....selected 1/8 microstepping, calibrated my axises -BINGO! (so as suspected a combination of low axis resolution & then missed steps which was causing large errors on my Z axis (& likely the other axises too)
I'm now quite content with the results, certainly the SOT23-5 (which only has 0.4mm of space inbetween the pins!) is fine by me....
(the pic below is massively magnified - that main IC toward the middle of the photo is an SOIC-14 package ...which is just about 8mm long)
(the stray islands of copper you see randomly peppered about the board - eg just above & below the SOT23-5 pads - I'm not worried about them, so it's not in my g-code to remove them)
Thanks for all your input....it's nice to put this one behind me!Last edited by HankMcSpank; 09-02-2012 at 01:46 PM.
09-02-2012 #38
Result looks great from here. What V-cutter did you use (angle, flat width)?
09-02-2012 #39
That was a cheap carbide V cutter from China - 20 degree angle, 7500rpm (ie the fastest my spindle goes), about 0.15mm depth)
09-02-2012 #40
Grand job Hank and good to see you are on your way again. Well done
VFD error
By routercnc in forum Spindles & Drive MotorsReplies: 37Last Post: 21-06-2014, 08:40 PM -
huanyang vfd 2.2 error E.CO.A
By edgas10 in forum General ElectronicsReplies: 0Last Post: 01-07-2012, 08:12 PM -
Ballscrew Woes, help please!
By jonbabbz in forum Lead Screws, Nuts & SupportsReplies: 9Last Post: 21-04-2012, 12:16 AM -
Solidcam error
By Kai in forum SolidworksReplies: 5Last Post: 10-05-2011, 03:41 PM -
Warco Drawbar woes...
By irving2008 in forum Machine DiscussionReplies: 7Last Post: 22-12-2008, 12:56 AM
