Thread: Z axis error woes
Grand job Hank and good to see you are on your way again. Well done
13-02-2012 #2
Thanks guys....would you believe that since my last "solved" post - my problems (missing steps) moved to my Y axis!!
Basically, to solve the former Z axis problems I put in place a chinese TB6560 board...it transpires the 6 way DIP switch (ie the one that sets the current, decay & micro-stepping) for the Y axis was faulty & therefore some of the individual DIP contacts weren't making properly - the outcome being my Y axis was actually only running at 25% current...which made my Y Axis lose steps, which wasted a lot of my jobs (not to mention a couple of days lost time!) ...the solution was to hard wire (with little strips of wire) across the contacts on the base of the DIP switch!
Should anyone be misfortunate enough to hit a similar 'missing steps' problem with a TB6560 board ...if you've the same issue as me it's actually easy to diganose (in hindsight!), the swishing sound made by your stepper changes if your press down on the overall DIP switch! (the switch itself is a nasty bit of manafacturing....I can see a lot of these giving problems)
An unbelievable bad run of luck - & speaks volumes for the importance of using good stepper drivers - that's two consecutive boards that have bit me in the arse in short order!
Mishinh' Shteps.....Shteppersh, schmeppers.... [to be muttered under your breath in a Muttley style]Last edited by HankMcSpank; 13-02-2012 at 07:14 PM.
13-02-2012 #3
Well hate to say it. . .BUT . . . Did say Scrap em and start again. .
Pleased you found it quick this time thou because it would have been hard for Epoz and me (Edit:Oh and musn't forget Jonathan.!!) to scrap over what this one was.!! . . . Sure we'd have made something up thou.:rofl:
13-02-2012 #4
Indeed you did...but that was related to the first board - not the replacement! (that I thought had solved all my problems...whereas in fact it solved the Z problems but introduced Y problems)....I was tempted to post here & pretend it's not sorted just to give you all a reason to squabble! :-)
& such is my present fragile state of mind with respect to CNC machines - I'd have certainly bought it!Last edited by HankMcSpank; 13-02-2012 at 07:49 PM.
VFD error
By routercnc in forum Spindles & Drive MotorsReplies: 37Last Post: 21-06-2014, 08:40 PM -
huanyang vfd 2.2 error E.CO.A
By edgas10 in forum General ElectronicsReplies: 0Last Post: 01-07-2012, 08:12 PM -
Ballscrew Woes, help please!
By jonbabbz in forum Lead Screws, Nuts & SupportsReplies: 9Last Post: 21-04-2012, 12:16 AM -
Solidcam error
By Kai in forum SolidworksReplies: 5Last Post: 10-05-2011, 03:41 PM -
Warco Drawbar woes...
By irving2008 in forum Machine DiscussionReplies: 7Last Post: 22-12-2008, 12:56 AM
