    Cutting Profiles with BobCAD-CAM
    Profile cutting is so common almost any 2D part you machine requires this type of tool path. From finishing the wall of a pocket to cutting around the outside shape of a part, profiling is essential.
    We offer 3 types of profile options that accommodate for different profiling needs. These options can be found under patterns of the Mill 2 Axis Wizard
    Standard:
    Our standard profile cuttings allow for a rough and finish tool, stock for finish, lead in / out options and step down in z. This is the most common profile cutting tool path.
    Watch a video to learn more: http://screencast.com/t/uaoSCEa1e
    Contour Ramping:
    This option allows you to ramp the tool around any profile. Common uses are for helical milling & slot milling. You control the angle of cut or a step down distance.
    Watch a video to learn more:http://screencast.com/t/PB7txTXU7RL
    Side Roughing:
    Allow you to walk the tool in to a profile. Works best where you have more stock to cut then the cutter can take on a single pass.
    Watch a video to learn more: http://screencast.com/t/4TNtJHmvWXW
    With all profile cutting features you have compensation options, Allowing BobCAD to offset for the cutter, or to call cutter comp (G41 G42). These compensation options allow for wear comp, cutter comp, and center line cutting.
    Using our profile tool path you can cut slots, shoulders, letters, holes, filets, t slots, dove tails, form shapes and other common every day 2D milling features.
    If you have any questions please let me know.
    Al DePoalo
    BobCAM Team Leader
    Al DePoalo
    BobCAM Team Leader
    Quote Originally Posted by aldepoalo View Post
    Standard:
    Contour Ramping:
    Side Roughing:
    Al DePoalo
    BobCAM Team Leader
    Thanks for sharing this, especially the video's, they were really good.
    No problem, if there are other topics you want covered just let me know.
    Al DePoalo
    BobCAM Team Leader
    Ajancnc's Avatar
    Location unknown. Ajancnc Last Activity: Has a total post count of n/a. Referred 6768 members to the community.
    It is a good post. Thanks for sharing this kind of information. Now a days it has grown up and it is the affordable and popular solutions. Because it has web-based direct sales approach.
    I would agree BobCAD has come a long way. Check out this video on 3D, let me know what you think.
    Al DePoalo
    BobCAM Team Leader
  1. Replies: 2
    Last Post: 07-12-2013, 04:13 PM
  2. aluminium profile for cutting bed of router
  3. options for 3020 router spindle?
    By arborealad in forum Milling Machines, Builds & Conversions
    Last Post: 19-11-2012, 10:13 PM
  4. Machine rebuild time - options...
    By CraftyGeek in forum Gantry/Router Machines & Building
    Last Post: 19-10-2011, 10:26 PM
  5. limit switch connector options?
    By routercnc in forum General Electronics
    Last Post: 04-09-2010, 02:11 PM
