Thread: voltage on motor wires
Have you measured the backlash in the rotary table? Can you link me to the rotary table as I don't recognise that one, or is it obsolete?
11-02-2012 #2
Don't know much about it I swapped a 6" same make Vertex for this 4" one, stripped it out, it is as new did not see any wear, fitted it out with some thrust bearings no backlash or tight spots so I guess I was lucky, (but they are well made) built it back up and away we go, not used it until last week then found the lost step problems.
Had a few settings to work through in Mach3 but now it works great, found a good program for wrapping, CNCWrapper so easy once you have your Gcode.
Not obsolete see here: http://www.chronos.ltd.uk/acatalog/V...cessories.html
What voltage for stepper drive?
By Davek0974 in forum Plasma Table MachinesReplies: 1Last Post: 22-01-2014, 10:49 PM -
Milliamps and voltage help please
By Fivetide in forum General ElectronicsReplies: 13Last Post: 30-09-2012, 01:36 PM -
Alternator low voltage
By M250cnc in forum General ElectronicsReplies: 12Last Post: 24-02-2011, 11:23 AM -
Bipolar motor voltage
By wildbill in forum General ElectronicsReplies: 10Last Post: 24-02-2010, 12:23 PM -
A brushless DC motor with no back EMF - E-Orbo current/voltage traces.
By machinevolt in forum General ElectronicsReplies: 8Last Post: 06-02-2010, 10:15 AM
