14-02-2012 #11
Thanks for that Tenson, its reassuring, especially to know to expect it to be tight on its threads :-)
Other thought had for low cost tooling is Dremel and clone cutters, these normally have a 1/8" shank and should fit supplied collet.
See that a Dremel is spindle of choice in some builds, do have an interest in milling PCBs amongst everything else ;-)
15-02-2012 #12
Just to update , Dremel and Dremel alike, 1/8" 3mm shank cutters, do fit nicely in supplied collet , been zipping through softwood with some Aldidl rotary tool cutters.
Proxxon tooling is 2.35mm diameter, different collet size.
Dremel branded tooling is ludicrously expensive, quite a lot of lower cost HSS and engraving bits available without the brand tag on them.
FOR SALE: For Sale, Chinese 1.5kw spindle (er11 collet) with matching VFD! with 4 & 6mm collet
By jcb121 in forum Items For SaleReplies: 1Last Post: 29-01-2013, 11:05 AM -
Stupid question I know... but - What size is my Spindle Collet ?
By Fivetide in forum Milling Machines, Builds & ConversionsReplies: 17Last Post: 25-11-2012, 03:34 PM -
3040 size router plans?
By m_c in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 24-06-2012, 04:15 PM -
ER11 Collet size lying?
By Philly in forum Tool & Tooling TechnologyReplies: 6Last Post: 14-04-2011, 12:26 PM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM
