Thread: Uniport and limit switches.
13-02-2012 #1
Hey guys, im having a problem with wiring my limit switches up to the uniport.
Do any of you good guys have a wiring diagram which i could go off or possibly give me a fool proof option :whistling:
13-02-2012 #2
sorry maybe i should mention i would like the switches to act as home switches also. i had one test switch hooked up and homed the machine pressed the switch and it backed off but didnt stop until i let off the switch
13-02-2012 #3
I've been thinking about changing my limit switches, I'm very interested by RS pn: 171-3808, a slotted optical flag switch.
Here's a data sheet: http://docs-europe.electrocomponents...6b80028ba3.pdf
It switches with a max force of 1.5gms, they all agree with each other plus minus 3 degrees and it has a good overtravel (infinite if you get the actuator angles right).
What they don't tell you is the hysteresis and repeatability for an individual part. Even without the benefit of a Schmitt there is a distinct possibility it could be freakin' amazing as a positioning switch.
I will order some today and report back.
13-02-2012 #4
13-02-2012 #5
13-02-2012 #6
Double post
13-02-2012 #7
Thats how home switches are supposed to work.! They hit the switch which triggers the signal state then reverse until the switch releases's and signal changes back to it's original state. Depending how you have them wired IE Normally open (NO) or Normally closed(NC) the signal will go Hi or Low the control software(Mach etc) just watch's for this change.
Wire them NC for safe operation then if a wire breaks or comes lose then the signals lost and machine stops.
The wiring is easy just wire them in series IE + - + - + - + -
13-02-2012 #8
cheers JAZZ, my switches only have 1,2,3 on them would 1 be the positive?
13-02-2012 #9
Do i have the right idea with this?
13-02-2012 #10
Robin,
I got family not to far from there. Might see if they have counter service and get a group order together if they do as that looks like a very nice set up and with just a little bit of shielding from FOD would be a very dependable switch.
Michael
EMC2 home/limit switches... only acting as limit?
By vputz in forum LinuxCNC (EMC)Replies: 4Last Post: 15-10-2014, 09:51 AM -
24v Limit/Home switches. How to..?
By Wal in forum General ElectronicsReplies: 6Last Post: 17-11-2013, 05:52 PM -
Limit Switches
By Leadhead in forum General ElectronicsReplies: 1Last Post: 16-10-2013, 10:41 AM -
Limit Switches with LED's
By manofgresley in forum General ElectronicsReplies: 30Last Post: 02-01-2013, 03:08 PM -
Limit Switches
By Lee Roberts in forum General ElectronicsReplies: 13Last Post: 27-06-2008, 02:21 AM
