Thread: Uniport and limit switches.
Yes but you can if you want to save inputs put them all on the same input X,Y & Z Axis.
The switch's 3 terminals would go something like this:
Terminal 1 = input
Terminal 2= output normaly closed or Terminal 3= output normally open.
To check which is which just use a multimeter set to continuity then probe between pin 1 and any of the others, one should show continuity when switch is NOT pressed, this is the NC switch, the other will show no continiuty untill switch IS pressed. This the NC switch.
Personally I would wire all the limits in series X,Y & Z to 1 input and the home switch's to another.
EMC2 home/limit switches... only acting as limit?
By vputz in forum LinuxCNC (EMC)Replies: 4Last Post: 15-10-2014, 09:51 AM -
24v Limit/Home switches. How to..?
By Wal in forum General ElectronicsReplies: 6Last Post: 17-11-2013, 05:52 PM -
Limit Switches
By Leadhead in forum General ElectronicsReplies: 1Last Post: 16-10-2013, 10:41 AM -
Limit Switches with LED's
By manofgresley in forum General ElectronicsReplies: 30Last Post: 02-01-2013, 03:08 PM -
Limit Switches
By Lee Roberts in forum General ElectronicsReplies: 13Last Post: 27-06-2008, 02:21 AM
