Thread: Home switching
    Vard's Avatar
    Lives in Yerevan, Armenia. Last Activity: 14-03-2012 Has been a member for 9-10 years. Has a total post count of 4.
    Hi everybody. I am beginner at CNC and EMC2 and need some help.
    My CNC kit is Probotix and it works with EMC2. But in the kit's documentation there is no home switch configuration, only limit switch is there. Here is the links of the kits documentations:
    PBX-2 CNC Parallel Port Breakout Board User Manual
    http://www.probotix.com/diagrams/4-A...ng_diagram.pdf
    Please help me how to configure to get home switching. Thanks in advance.
    You decide if the switch is a home or limit by selecting what it is in the control software config.
    Vard's Avatar
    Quote Originally Posted by 2e0poz View Post
    Thanks for advising.
    NB70's Avatar
    Lives in Swansea, United Kingdom. Last Activity: 01-04-2025 Has been a member for 9-10 years. Has a total post count of 61. Received thanks 10 times, giving thanks to others 9 times.
    You can also use switches as both home and limit, that is how I have mine set up.
    Vard's Avatar
    Quote Originally Posted by NB70 View Post
    Ok. Can you show/tell me how to wire your mode?
    NB70's Avatar
    Just wire it as shown in the pdf diagram in post#1.
    Then set input pins 11 as "Both Limit and home Z", 12 as "Both Limit and home Y" and 13 as "Both Limit and home X" in the parallel port page of the EMC2-stepconf program.
    When the EMC2 (its now called linuxcnc) is in homing mode it will move each axis in turn in its specified homing direction until it trips the limit switch and then slowly back off the switch until it opens again. Be careful to set the direction of home search velocity as negative if your home switches are located at the axis minimum, & make sure your emergency stop is working before you test the homing procedure!
    Quote Originally Posted by Vard View Post
    Vard's Avatar
    Thank you very much. Your explanation really works!
  1. switching from steppers to servos - STEP / DIR control
    By dsc in forum Stepper & Servo Motors
    Last Post: 18-06-2014, 12:41 PM
  2. Driver switching OFF
    By manofgresley in forum Artsoft Mach (3 & 4)
    Last Post: 06-06-2014, 04:57 PM
  3. FOR SALE: 24v 20 amp ABB switching power supply £90
    Last Post: 07-02-2014, 07:42 PM
  4. Home is where the part is?
    Last Post: 15-07-2013, 09:58 AM
  5. Home made CNC for 50 €
    By Lee Roberts in forum Gantry/Router Machines & Building
    Last Post: 26-05-2009, 08:12 PM
