Thread: 6040 router
Page 2 of 2 FirstFirst 12
  1. I've a 6040 router that has a dead driver board so I'm planning to replace it with a Gecko G540. I have a 48V supply I was going to use but wanted to find out the specs of the motor. Nothing useful from the supplier other than a 3A current rating. Despite an extensive googling, I'm no wiser.
    Here's the label on the motor
    .Click image for larger version.
    Regards
    Geoff
    My home
    Quote Originally Posted by tumutbound View Post
    found this but not much more info
    http://www.google.co.uk/url?sa=t&rct...28b3aQ&cad=rja
  3. Finally found time to work on this machine.
    I built a new controller using a Gecko G540 with a 48V power supply. I've still no idea what the inductance of the motor is but it runs well with no overheating. In trying to track down an annoying roughness (motor tuning was to blame), I found a couple of mechanical issues with the X and Y axis bearings. Nice and tight on the ballscrew but loose in the endplates. The motor end of the ball screw has a single bearing and the other end, two bearings. None seem to be angular contact type. Lacking a working mill, I'm going to put a shim around the bearing to make it a tighter fit. I'll check out the options for fitting better (angular contact) bearings to the existing end plates if possible.
    Regards
    Geoff
    My home
    hi i have the same 6040 cnc and would like to ask what is the setup in motor tuning step per mm that you put in the software thx for your help
    im using mach3 and no clue what to put in motor tuning
  1. What is your opinion of the CNC 6040 Router Machine ?
    By John S in forum Chinese Machines
    Last Post: 30-11-2023, 10:58 AM
  2. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  3. Chinese 6040 CNC Router Advise Needed
    By Bob Hepple in forum Chinese Machines
    Last Post: 27-11-2013, 12:00 PM
  4. suggested equipment to retro fit a 6040 yoocnc
    By madprof1 in forum Milling Machines, Builds & Conversions
    Last Post: 03-12-2012, 09:52 PM
