Thread: Thread diameter
Hi
What die do I need to put a thread on a SS shaft,the thread is metric and has a reading of 10mm on my caliper.
I think it would be 9mm die but need to be sure before I buy one as I have seen 9.5mm ones as well.
Thanks.
	22-02-2012 #2
could you clarify the dimension 9mm or 95mm you are talking about. to make a m10 thread you need a m10 die
	23-02-2012 #3
Daniel,
you need to measure the thread, the TPI (threads per inch) as well as the diameter to find out what you need. At 10mm you could have either a 1.5mm thread or a 1mm thread. 9mm would not be a standard thread.
If you need die nuts send me a PM.
Ian
	23-02-2012 #4
A 9mm(M9) is a standard thread just not very common, i know i have them on my lathe :-(
	23-02-2012 #5
M10 x 1mm is not very common either Daniel the post common would be M10 x 1.5mm.
	23-02-2012 #6
2e0poz,
thats what I meant to say. Just the most common or standard threads would be 6, 8 or 10. Although I do have a set of 7mm x 1mm somewhere that I used for repairing an old machine which was scrapped a while ago. One day they might come in useful again.
10mm x 1mm or metric fine I come across alot. It seems to be quite common on some machines.
	23-02-2012 #7
	23-02-2012 #8
I went through every screw tap in imperial sizes before i found out, it was real pain because i was not expecting a 9mm thread. His thread would be a 10 though as thread itself would be just under. Zeus guide is mans best friend in the workshop
Optimal ballscrew diameter for lathe
By vre in forum Lathes, Lathe Rebuilding & ConversionsReplies: 6Last Post: 20-03-2014, 02:44 AM -
Tool diameter accuracy
By Neale in forum Tool & Tooling TechnologyReplies: 15Last Post: 05-03-2014, 11:18 PM -
Knurling Pitch and diameter calculator spread-sheet
By Fivetide in forum Metalwork DiscussionReplies: 1Last Post: 22-09-2012, 11:17 PM -
Sieg Mini lathe - smallest diameter rod turn-able?
By HankMcSpank in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 18-11-2010, 01:15 PM -
optimum diameter???
By m.marino in forum Lead Screws, Nuts & SupportsReplies: 4Last Post: 02-04-2010, 12:44 AM
