Thread: AutoEditNC alternative?
Thanks 2e0poz, but it sounds like no-one here has ever tried AutoEditNC!
It's not just a code editor – there are dozens of free ones (like Notepad++), and I have a few "programmer's editors" already (Crimson Editor is my favourite). The feature that distinguishes AutoEditNC is its G/M-code 'hint' facility. You click on the G or M button, and from the list of available codes, select the one you want to use. It then presents a pop-up window with the syntax for that code (and often an explanatory diagram), including its arguments (if any) and an explanation of exactly what it does. You can then edit those arguments in the pop-up, click the 'Add this command' button, and that command, with arguments, is added to your file at the cursor insertion point. (You can also click the 'Add..' button without editing the arguments, and edit the defaults it provides, within your code file.)
This is a great help for an occasional programmer like me, who (because I do it so infrequently) can never remember the argument details for the more complex commands without referring to a quick-reference sheet or similar.
If only AutoEditNC worked properly, it would be ideal. So I'm looking for a similar editor with a similar 'hints' feature, that works reliably.
Anyone seen one??
Rgds, Daniel
22-02-2012 #2
Yes Daniel the G-wizzard editor/backplot works pritty much the same, theres a list of G -M codes with all the param's and you just insert. It doesn't let you enter param's on this screen but does after it's been inserted,it also checks the formats correct and highlights red if error, green ok. I will suggest they add a box so param's can be entered on list screen,this would be usefull edition.
It's still a work in progress and running very very slow on my system, which hisn't slow it's an i7 Laptop with 12GB so it must be software issue or it just don't like my system.?
The only down side like John S says is the fact it installs Adobe shite and it has to phone home else it won't work. . . .Oh and when it's released you'll still have to buy/rent it.
Worth a look thou because I dont know of anything else that comes near.!
22-02-2012 #3
John & Jazz, thanks for your further input. Because CNC machining is very much an occasional adjunct to my main hobby, I won't be using it often enough to ever become 'proficient' at G-code programming. For the same reason, I'm unlikely to spend big money on some program that might generate the required G-code for the complex projects I will do occasionally.
And I'm fussy about what goes onto my already-too-slow main PC (not the one I use for CNC machine-control, but the one I design/program on), so don't like the sound of G-Wizard's accoutrements.
Looks like I'll just have to continue with my quick-reference on one half of the screen (kept there with NailIt) and a simple program editor on the other half, and copy-and-paste from the QR to the code window, when required. It's just a very 'squeezy' arrangement on my small screen.
I'll see what I can find about Discriminator. Thanks again, guys.
Rgds, Daniel
Heidenhain ME 101 Tape reader or alternative program storage.
By corkcnc in forum Machine Control SoftwareReplies: 3Last Post: 19-03-2014, 11:28 AM -
CW8060 or alternative?
By Tenson in forum Motor Drivers & ControllersReplies: 4Last Post: 03-02-2014, 07:56 PM -
Alternative slides and guides
By Swarfing in forum Rails, Guideways & BearingsReplies: 14Last Post: 23-04-2012, 07:14 PM -
Cheap Sign Foam Alternative
By action-kat in forum Machine DiscussionReplies: 5Last Post: 20-09-2011, 12:35 PM
