Thread: My 1st homebrew CNC.
I would just make two more trucks and extend the bolts you are using for bearing axles to attach the new truck at 90 degrees. With a bit of shimming the bearing which will now be underneath the tube can be made to contact it quite securely. So hard to describe this in words
Basically, keep the truck as you have it but bolt on another identical truck using the axle bolts from the first then shim. This will also allow you to support the rail with no interference. This will do what you want. You only need one extra truck per side so two new trucks to make Kammo, shouldn't take more than 15 mins so get cracking!
Jeff.Last edited by Smiler; 22-02-2009 at 01:11 PM. Reason: I forgot a bit
Homebrew Allegro uStep Driver
By epninety in forum Electronic Project BuildingReplies: 0Last Post: 06-09-2011, 11:11 PM
