    Well I've done it Yes I've cut my first aluminium on my CNC Machine and it feels good NO tool breakages and I think a descent chip-load to start with :rofl::rofl::rofl::rofl: I only cut .75mm a pass but it's a start the machine ran at around 1650 and a spindle speed of 1300 tool size 4mm endmill. I only made one mistake and that was at the start second tool change I forgot to raise the spindle up after screwing the work down but I am still quite new But I don't do this often in fact it's the first time I've left the spindle to low I will post a Video and Images later today as I have a friend coming around to fix his car
    These brackets are intended for my X-Axis limit switches with adjustment ​
    James
    Well done James.
    Its nice to get that first one under your belt. I have a little job of 12 parts to get done for end of this week on 25mm thick ali.
  3. Well done, James and Luke.
    Michael
    Quote Originally Posted by luke11cnc View Post
    I feel your pain James.!! . . . Bloody friends pain in the arse always bugging me getting in the way of good CNC time.!. . . Daft thing is the more folks I help the more friends I gather the less time I get to CNC.!!. . . . . Better than being Billy no mates thou.:rofl::rofl:
    Congrats on first hot chips. .
    It must be your magnetic personality :dance:
    John S -
    well here it is iamges if you want of the finished item just let me know and I will post some up
    So here is the video of my First aluminium cutting I must admit I quite enjoyed it
    http://youtu.be/vLhKupoQwWg
    for some reason I didn't video the V-carve shamfer on the brackets O'well you can see the finish and I'm quite chuffed to bits with my self.
    I am always open to comments GOOD OR BAD as this is the only way to learn
    in all with three tool changes and stopping to screw it down (30 min a lot of holes as well)
    James
    Looks good james. .
    Tip: Get your self a small compressor and blow the chips away so they don't get re-cut, much better finish and far easier on the cutter. . . . OR . . . Better still do like I've just done and mount the machine vertical on the wall.:whistling:
    NO I'm just a silly bugger who's too soft and works cheap..:rofl:
    Jazz you get paid for working on friends cars ?
    O'bugger that's why there's a long line of cars out side my door wanting work done on them
    well after I've finish patting myself on the back I have a question about the cutting I've done
    this is only apply's to the x-axis cut. I seam to have a ribbing affect on the cut line and this is constant through out the job.
    Any Ideas on what has happened
    I will post a image later
    James
    I've had a chance to take some images of the work I cut yesterday
ID:	5381Click image for larger version.
ID:	5382Click image for larger version.
ID:	5383Click image for larger version.
ID:	5384Click image for larger version.
ID:	5385Click image for larger version.
    I Hope you can see the ribbing this ribbing was cut from the X-Axis
    Was the machine feed rate to fast ??
    James
  1. Aluminium box section
    By martin54 in forum Gantry/Router Machines & Building
    Last Post: 28-10-2012, 01:13 AM
  2. BUILD LOG: Aluminium CNC log.
    By jcb121 in forum DIY Router Build Logs
    Last Post: 04-04-2012, 01:37 AM
  3. RFQ: Aluminium sculpture to be CNC'ed
    By dav in forum Projects, Jobs & Requests
    Last Post: 07-01-2012, 04:37 PM
  4. Aluminium passivation - for aluminium to be used outside
    By CHudson in forum Metal Finishing Techniques
    Last Post: 06-04-2011, 09:18 PM
  5. MDF or Aluminium
    By rob_colby in forum Gantry/Router Machines & Building
    Last Post: 24-10-2010, 09:36 PM
