Thread: First Aluminium cut
well here it is iamges if you want of the finished item just let me know and I will post some up
So here is the video of my First aluminium cutting I must admit I quite enjoyed it
http://youtu.be/vLhKupoQwWg
for some reason I didn't video the V-carve shamfer on the brackets O'well you can see the finish and I'm quite chuffed to bits with my self.
I am always open to comments GOOD OR BAD as this is the only way to learn
in all with three tool changes and stopping to screw it down (30 min a lot of holes as well)
James
22-02-2012 #2
Looks good james. .
Tip: Get your self a small compressor and blow the chips away so they don't get re-cut, much better finish and far easier on the cutter. . . . OR . . . Better still do like I've just done and mount the machine vertical on the wall.:whistling:
Aluminium box section
By martin54 in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 28-10-2012, 01:13 AM -
BUILD LOG: Aluminium CNC log.
By jcb121 in forum DIY Router Build LogsReplies: 111Last Post: 04-04-2012, 01:37 AM -
RFQ: Aluminium sculpture to be CNC'ed
By dav in forum Projects, Jobs & RequestsReplies: 6Last Post: 07-01-2012, 04:37 PM -
Aluminium passivation - for aluminium to be used outside
By CHudson in forum Metal Finishing TechniquesReplies: 4Last Post: 06-04-2011, 09:18 PM -
MDF or Aluminium
By rob_colby in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 24-10-2010, 09:36 PM
