    I have completed building my machine and have it working well, except for having a motor to become demagnitized. Waiting for replacement now. I have cut several demo projects without problem. I trying to cut the picture of the sign below. The blackouts are for privacy. I have drawn the image in Inkscape, so I have in in DXF and SVG formats. The pic is for ease of show here. I have tried various ways of encoding to G-code but have been unhappy with the results. The idea is to have all the white areas removed -.25" from the block faced leaving the black areas in standout. I have messed around with pycam, g-simple, lazycam and kcam. The best result was with image-to-gcode; however, with a 1/16" bit it took hours to complete and may have helped with the demagnetizing of my x-axis stepper. This is a large plaque about 15" x 15". I need some help and advice.
    stumped.
Name:	cnc forum pic.png
ID:	5379   Click image for larger version.
    Try Cambam http://www.cambam.info/ this will easily do what you want.
    Since your a linux user it will run under xp from Virtual box.
    Thanks for the info. CamBam was great. Short learning curve and I could do all the things I needed to for the plaque. Here is a picture of the first one. Waiting for approval from the board and then I have at least 14 more to do. Oh, and by the way I am not a linux user.
Name:	first plaque image.jpg
    Ah it was Inkscape and pycam that prompted me to say that........Well we can't save everybody? Glad to you are up and away anyway...good job
    Still XP, but I try to use as much open source software as possible. Thanks for the help and the comments
    gooooood man!
  1. Can't generate a 'correct' contour
    By palr717 in forum CAD & CAM Software
    Last Post: 24-02-2014, 01:08 PM
  2. How to generate Lathe GCode from a drawing?
    By Robin2 in forum Computer Software
    Last Post: 25-10-2013, 04:04 PM
  3. Cambium Code Web Tools – Parametric G-code Generation
    By CambiumMachines in forum Manufacturer News
    Last Post: 09-01-2013, 04:56 AM
  4. Easy way to generate dxf files
    By 2006Nobull in forum CAD & CAM Software
    Last Post: 10-08-2011, 09:44 PM
  5. Replies: 0
    Last Post: 29-06-2011, 05:37 AM
