Thread: Hello from Bristol
Many thanks Kip, this is the conclusion i am coming to. No matter how much money you throw at this sort of thing, unless you have say £20,000 just hanging around, burning a hole in your back pocket, an of the peg machine just would not make the grade. Where as you would have a greater sense of achievement if you created something, it worked, and you had overcome all the problems associated with building such a machine. That is what a hobby is all about.
First is to find someone with an extensive supply of steel and aluminium;)
Matthew
09-11-2008 #2
09-11-2008 #3
Matthew,
What is your expertise in design and build of such a complex beast? Not wishing to be negative but unless you are working to a known design some idea of what you want to build and how its going to go together needs to come before buying materials, or did I understand right that you were going to have a stab at copying an Elu? What makes you think that the Elu is the right design for what you have in mind?
10-11-2008 #4
Hello Irving2008 & All
The size of machine would be one that would take about the size of a kitchen carcass. I have one machine in mind, where the beam goes under the bed in a U shape, and the U shape can move backwards and forwards under the bed with ballscrews
I have no plans cast in stone as yet, but an Elu certainly ticks a lot of the boxes.
Matthew
NEW MEMBER: New member from Bristol
By jamesgates1000 in forum New Member IntroductionsReplies: 0Last Post: 24-02-2014, 12:24 PM -
NEW MEMBER: New member - Bristol
By Coldsolder in forum New Member IntroductionsReplies: 1Last Post: 14-01-2011, 06:21 AM -
NEW MEMBER: new member from bristol
By iamspuddy in forum New Member IntroductionsReplies: 1Last Post: 11-01-2011, 03:30 PM -
NEW MEMBER: hello everybody, Bristol
By HypnoToad in forum New Member IntroductionsReplies: 3Last Post: 09-09-2010, 12:11 AM -
NEW MEMBER: New Member - Bristol UK
By spyder.boy in forum New Member IntroductionsReplies: 1Last Post: 05-10-2007, 09:33 AM
