Thread: Time to go vertical.!
24-02-2012 #3
Well they do say neccesity is the mother of all invention.!!. . . I needed the space back . . BUT . . I'm not the first and there's even professional versions.
Well yes and no really. If you need longer than bed material then just mount it horizontal. In my case I dont ever hang material off the bed so it's not a problem.
Also the machine doesn't sit directly on the floor and infact will be on a steel boxsection frame thats bolted to the floor and supports the machines frame and allows for adjustment.
Also the machine is raised about 12" at rear and 18" at front due to being angled back. Infact really the machine will be effectively free standing and doesn't need a wall thou mine will be mounted against the wall with shock absorbing rubber mountings. (At the minute it's sat on concrete blocks and axle stands with a few bolts into wall)
The whole bed is easily reached, far easier than when flat. Straight away in use I knew this was going to be a big bennifit to me and my Bad back because reaching over my wide bed when clamping large jobs killed me, esp if I'd been stood watching over the machine for a while.!!
Frame is all 50x50 box section steel.
Vertical router design
By EddyCurrent in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 29-03-2014, 10:43 PM -
Why not vertical?
By irving2008 in forum Gantry/Router Machines & BuildingReplies: 17Last Post: 17-09-2012, 07:20 PM -
Vertical Machining Center Info
By benkat in forum Milling Machines, Builds & ConversionsReplies: 7Last Post: 13-04-2012, 03:12 PM -
axyz vertical cnc router
By flanagaj in forum Manufacturer NewsReplies: 0Last Post: 30-12-2011, 10:39 AM -
Vertical moving gantry????
By Ross77 in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 03-06-2009, 08:34 PM
