Thread: Time to go vertical.!
24-02-2012 #2
Ah ah a bit prittier than my beast.!! . . Thou very sure it's no more accurate or sturdy and 10 times the cost.!!
This orientation was going to be my first choice and if building from scratch then thats how it would be done but the way my machine built it suits me better how it is.
Bruce just for you I've done a quick vid showing it in all it's glorious roughness warts n all.!!
Has you'll see it's very very very very rough at minute, the frame will be braced and cut so it goes back another 18" it will also bolted to a load bearing supporting frame which allows for adjustment, this will be bolted to the floor not the wall.?
I had concerns about the wall expanding with heat and shaking with high winds and this movemnet transfering into the machine. The supporting frame will handle supporting the top and at most I may just butt upto wall with rubber buffers. May even put lift up/down wheels so it can be rolled in and out then anchored to floor, thou think it will be a bit top heavy for moving around too much but will allow for easy access if something breaks.!!
All in all it will stand off the wall 1mtr(40") this is to the top of the Z axis when raised which is it's most protruding point. When parked with Z axis down just above bed it's 850mm(34").
This will be it's parked position when not in use and the gantry will come to rest at the bottom on some rubber buffers to take the strain off the ballscrews when not in use (Sarah's idea Micheal's wife, she's not just a prity face smarter, sharper than a laser cutter).
Didn't push it flatout only 5mtr/min 10mm DOC. because of very knackerd 6mm single flute cutter and no water in spindle, you can tell from the sound the cutter didn't like it and infact after this I tried to cut straight thru 13mm and it got half way and snapped cutter.!! . . .didn't stall thou which I was happy about.:dance: . . . . AND. . . Just look at the room I've got back in the shop plus when it's all finshed and further back with coolant and chip collection try in the bottom along with doors on front so full enclosed it will be brilliant. .
Won't happen for a week or so because I'm wanting to fully test just in case any gremlins appear that I hadn't foreseen. I will cut several jobs with where it is, these will be a good test because there long-ish jobs in Ali and even some mild steel slots so should show any issue's. . . . I've also got to finish off the electrics new home.!
Here it is and don't comment on the state of the shop or machine.!! . . .Yes I know it's rough engineering at it's best and an untidy shit hole.!
http://youtu.be/pjJ88n-ynx0
Vertical router design
By EddyCurrent in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 29-03-2014, 10:43 PM -
Why not vertical?
By irving2008 in forum Gantry/Router Machines & BuildingReplies: 17Last Post: 17-09-2012, 07:20 PM -
Vertical Machining Center Info
By benkat in forum Milling Machines, Builds & ConversionsReplies: 7Last Post: 13-04-2012, 03:12 PM -
axyz vertical cnc router
By flanagaj in forum Manufacturer NewsReplies: 0Last Post: 30-12-2011, 10:39 AM -
Vertical moving gantry????
By Ross77 in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 03-06-2009, 08:34 PM
