Thread: Setting up stepper motor drivers
26-02-2012 #1
Hi, i need some help/advice on setting up stepper drives, Currently trying to CNC my lathe i have a 14mm dia x 4mm pitch ballscrew for the leadscrew and a 8mm dia x 2mm pitch for the cross slide.
i have a Nema 23 on the leadscrew and a nema 17 on the cross-slide. these are driven MSD542's powered by a 50V DC 10A power supply.
I have setup the micro drivers to 8 microsteps, Is this possible too much? as the motors sound rough.
Some background ( i had the drives etc working on the old 8 TPI leadscrew) so there is no problemas with power motors or drivers..
RoyRegards,
Roy Stark
26-02-2012 #2
Roy,
Have you tried any other settings ?
How are you connecting the motors to the screws ? Oldhams or lovejaw type couplings ?John S -
26-02-2012 #3
50V supply on 50V drive is bad idea.! . . . your in danger of back emf frying them on de-acceleration. On a lathe it probably won't be a massive issue because it wont be de-accelerating from high feeds but @50V your on the edge.!!
First I would double, triple check all your wiring, esp the motors phase connections.
Check your amps are not set too high on drive, then like john says try other settings.
What model motors are they.?
How have you got the motors wired.? Parallel or series or unipolar.
26-02-2012 #4
26-02-2012 #5
26-02-2012 #6
Try different velocity and acceleration settings in Mach
John S -
The Following User Says Thank You to John S For This Useful Post:
26-02-2012 #7
26-02-2012 #8
Hi No i dont think i have.
Dont worry i am not offended just grateful for the helpRegards,
Roy Stark
26-02-2012 #9
26-02-2012 #10
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
3 wire stepper motor drivers?
By m_c in forum Stepper & Servo MotorsReplies: 0Last Post: 17-08-2013, 10:01 PM -
Purelogic featured stepper motor drivers PLD86 and PLD545.
By Purelogic R&D in forum Manufacturer NewsReplies: 0Last Post: 07-06-2012, 08:36 AM -
Total novice seeks advice on stepper motor drivers
By R.Andersen in forum Motor Drivers & ControllersReplies: 1Last Post: 25-01-2012, 11:34 AM -
eBay Stepper Motor Drivers from China
By Mad Professor in forum General ElectronicsReplies: 6Last Post: 20-07-2009, 10:54 PM
