Thread: mach 3 help
27-02-2012 #4
As a newbie myself couple of things that have puzzled me to start with..
Did you get a P.C. with Mach3 running on it , or just a disc with Mach3?
If your installing Mach3 , need to make sure the parallel port is enabled from the bios on the P.C. your using. Older P.C.s can have had the parallel port switched off when they got a usb printer, took a while for me to spot that one...
E-Stop is on when Mach3 starts, the twinkling reset button bottom left.
Its a bit of a learning curve but one that definitely rewards the effort :-)
Adam
MACH 3 requirements
By manofgresley in forum Artsoft Mach (3 & 4)Replies: 14Last Post: 08-01-2020, 07:22 PM -
Mach Turn
By Kai in forum CAD & CAM SoftwareReplies: 5Last Post: 02-08-2016, 02:40 PM -
Mach 3 using laptop and usb
By drftnr34 in forum Motor Drivers & ControllersReplies: 6Last Post: 09-07-2015, 04:38 PM -
RFQ: Triac / Mach 3 help
By suesi34e in forum Projects, Jobs & RequestsReplies: 0Last Post: 10-08-2013, 01:59 PM -
NCStudio or Mach 3 or something else?
By Fivetide in forum Machine Control SoftwareReplies: 7Last Post: 01-09-2012, 05:41 PM
