I agree with John S. If you leave any springs or gears in the Z drive you will come to regret them.
Best to make the plate detatchable from the screw. That way you can still use the sensitive drill handle and you don't have to hammer against the screw when you dislodge taper tooling.
27-02-2012 #2
Thanks, like this advice, this is what I wanted to hear. For a while thought this is it, need another mill, but now there is some light.
Had another look at the mill today.
1) Z-axis (the original question)
- Do you think it might be best to fit the ball -screw as in picture?
-- (and yes make attachment -plate detachable from screw)
- Or perhaps try to hide the screw inside the "tower"?
- Or attachment to the quill ?
2) The Z-axis screw is possible to disable. (picture)
- perhaps one could leave it there, then?
- or would you take that out altogether?
3) Noticed, actually there is slack in X/Y -axes,too.
- So while we are at it, maybe retrofit ball screws, there too?
- How to choose correct ball-screws?
-- Length: existing screws + a bit more?
-- Diameter: similar to existing screws? (does it matter if they are not quite the same?)
-- Where to go from here? Take the table apart, to measure existing screw? Make a mockup / sketch?
- View from underneath of my mill (X/Y -table)
4) X/Y -table drawing / plan of parts to change?
Would appreciate any comments (no need to answer all questions). Sorry for a long post . Thanks!
CONVERSION: Round Column Mill Conversion - Looking for advice on Z-axis
By cnc-joe in forum Conversion Build LogsReplies: 0Last Post: 06-10-2013, 01:22 PM -
RFQ: DIY amp case help with materials and HUGE pre made cost justification !
By Fivetide in forum Projects, Jobs & RequestsReplies: 6Last Post: 04-06-2013, 12:05 PM -
BUILD LOG: beginning steps to building my cnc
By scnc in forum DIY Router Build LogsReplies: 24Last Post: 03-12-2012, 10:38 PM -
CONVERSION: Buget Warco Major 5 axis conversion
By Tweaky in forum Conversion Build LogsReplies: 45Last Post: 07-10-2010, 04:26 PM -
Ron Steele Mini Lathe CNC Conversion - Z Axis Leadscrew?
By No1_sonuk in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 17-05-2010, 12:47 PM
