    Was looking on ebay for the other day for cnc machines and came across this http://www.q-gee-graphics.co.uk/MDF_...0_5867758.aspx
    Has anyone got any experience of this company and what are your thoughts on its capability as a small hobby machine for just using at home?
    Thanks, Aaron
  2. There are a couple of threads over on cnczone.com about q-gee graphics that you might want to read. A couple of unhappy buyers.
    Regards
    Geoff
    My home
    We have just bought the same machine.
    How did you connect the motors to the plastic frame. I mean mounting wise? We didnt buy the mounts due to having a budget.
    Check out our thread if you have time, we're after all the help we can get :tup:
    Rgds.
    Adam, Alan, Josh, Steve, Mike.
    Quote Originally Posted by WollyUK View Post
    Rgds.
    I havnt purchased one yet because I wanted peoples views on it before I possibly wasted my money. With regards to mounts for the motors I couldn't see any pre drilled holes in the frame so I assumed I would have to find my own way of mounting them? Perhaps threaded rod and some bolts??
    Quote Originally Posted by bigdazza18 View Post
    Definitely wasted your money, not possibly. I've mentioned it many times before on this forum, so I wont repeat myself but any machine made with MDF or unsupported rails, let alone both, will be exceptionally weak. Probably fine if you just want to cut PCBs but that's about it. Search on this forum for explanations...
    What do you want to make with the machine?
    Right o.k. Yes there are pre-tapped holes there. I think i know what you mean with thr threaded bar. Maybe an m5x70mm allen bolt and use a bit of pvc pipe for structure strength.
    We'll figure it out, i'm sure. Probably post a few pictures if anyone was interested.
    I would be interested to know how you get on as I like the price of this machine but not the various opinions I have been hearing. Here is a pic of a mounted motor that I saw. Please bear in mind I know nothing about CNC machines and there construction, its only something ive seen.
    Out of interest what will you be making with it?
    i2i's Avatar
    I tried to go up and have a look at their premises which just looks like a house, but i was advised that they were just moving and it would not be possible. I wonder if they've finished their move and it's possible to view something. I'll chase that one up, as i live about 20 miles from them.
    i2i's Avatar
    Tube pillars would be better than just threaded rod.
    Hmmm... I'm not too convinced. I see your point with un-supported rails etc.
    But (and this is where we're going to get a bit geeky with our engineering here lol) the rails are 350mm long and 16.0005mm diameter, we're guessing their toughened steel. Meaning the Transverse loading weight (which would actually have to be made by the machine it's self, unless you are putting something heavy on the machine) would have to be 96kilo's per 100mm to get a flex of <1mm. devided by the 350mm rail length would mean an actuall transverse loading of 27 kilo's from the part that moves back and forth (Y axis?) and even more on the side to side axis as it is only 300mm (32kg-<1mm)
    We couldnt find any stats on the density of the HDPE frame it's self that we have.
    But the way the machine is setup, from what we can see all the "shear" strength is taken by the rails.
    Given that the distance between the rails on the weakest part of the machine, the side to side (it's the weakest as the most energy is being put there when in motion and cutting) is 80mm, and the risen height from the bed (the place where the force is generated) is 100mm, theres a good ratio for ultimate strength.
    It hasn't been used yet, but a simple (by pushing it with an arm) the uniaxial compression from the top right of the machine on a 45 degree angle is pretty solid with no flex up until about 15 kilos.
    If i could remember the formular to workout what kind of force in kg that would be at the cutting edge then i would let you know.
    We only have to PCB engrave with it ayway, so by rights a machine made from cardboard would probably be strong enough lol.
  1. The CNC machine I won on ebay
    By cubikoman in forum Machine Discussion
    Last Post: 08-02-2015, 09:02 PM
  2. Just a little video i found
    By totts in forum General Discussion
    Last Post: 18-04-2014, 09:37 AM
  3. Machine on ebay what do you think
    By alboy in forum Marketplace Discussion
    Last Post: 23-09-2013, 12:51 PM
  4. CNC Machine on ebay dodgy ????
    By dannyj2009 in forum Marketplace Discussion
    Last Post: 25-04-2013, 04:41 PM
  5. At last, found the bug
    By Robin Hewitt in forum Stepper & Servo Motors
    Last Post: 20-12-2008, 07:14 PM
