Thread: King Midas mill conversion
31-03-2012 #11
Just had a look at the drawings again...
You've currently drawn the Z-ballscrew with similar end machining to the X and Y screws which will put the screw in tension. On the Z-axis putting the ballscrew in tension is surely such a large force that it will pull the quill to one side. You also can't really combine a quick release with a tensioned screw as it would take too long to setup every time.
CONVERSION: Sx3 mill conversion
By dazza in forum Conversion Build LogsReplies: 1Last Post: 29-04-2014, 10:23 AM -
NEW MEMBER: Saying hello, about to start a mill conversion.
By irgonomics in forum New Member IntroductionsReplies: 4Last Post: 28-04-2013, 03:35 PM -
Mill conversion to cnc
By wolsey in forum General DiscussionReplies: 1Last Post: 15-08-2011, 11:07 PM -
NEW MEMBER: Hi From King's Lynn
By dialman in forum New Member IntroductionsReplies: 1Last Post: 13-10-2010, 09:59 PM -
Help with drill-Mill conversion
By Ross77 in forum Milling Machines, Builds & ConversionsReplies: 134Last Post: 02-04-2010, 10:25 AM
