    Have you tried tightening the two nuts in picture C against each other, so that they lock on to the thread, then use the inside one to unscrew the threaded rod? If it's in a tapped hole that should get it out.
    I wouldn't worry too much about the hand lever. I tend to remove the hand levers on my mill when I'm using it with CNC since they have a tendency to hit stuff (or me) if I don't!
    A small update:
    - the pinion gear eventually came out by punching the bearing out, slowly and carefully, from the opposite side
    - here is the gear/bearing that came out - this is all obsolete now
    - now the Z-axis looks mean and lean (LEFT: BEFORE, RIGHT AFTER)
ID:	7183Click image for larger version.
    - Now, I have bought a pile of these sort of building materials, and plenty of short 5mm bolts/nuts
    -- They are made from galvanized iron, (or the more expensive ones, are stainless steel, very rigid)
    -- Aim to attach bearing mounts to structures made from these building materials
    -- This is cheap, but thought would make a running mock up with them.
    -- Hope that way one could run the machine a bit, check dimensions again, check where to improve --> then make rigid, nice looking parts from aluminium.
    Maybe this ugly duckling will turn to a beautiful swan some day.
ID:	7184 Click image for larger version.
ID:	7185 Click image for larger version.
ID:	7186 Click image for larger version.
  1. CONVERSION: Sx3 mill conversion
    By dazza in forum Conversion Build Logs
    Last Post: 29-04-2014, 10:23 AM
  2. NEW MEMBER: Saying hello, about to start a mill conversion.
    By irgonomics in forum New Member Introductions
    Last Post: 28-04-2013, 03:35 PM
  3. Mill conversion to cnc
    By wolsey in forum General Discussion
    Last Post: 15-08-2011, 11:07 PM
  4. NEW MEMBER: Hi From King's Lynn
    By dialman in forum New Member Introductions
    Last Post: 13-10-2010, 09:59 PM
  5. Help with drill-Mill conversion
    By Ross77 in forum Milling Machines, Builds & Conversions
    Last Post: 02-04-2010, 10:25 AM
