Thread: Newbie CNC Build
15-03-2012 #19
@JAZZCNC: Thanks for the Great information and your time for posting.
I have started working on the Steel base Structure, I have the overall size but height will be adjusted/tweaked as soon as I get the machine completely drawn up.
Here is what I have so far, I am using 100mmx50mm Steel Box with 3mm wall, I am sure this will be more than strong enough.
Is there anything the looks glaringly/obviously wrong?
I will continue to work on the Design and keep everyone posted.
I am not quiet following you here, could you show me an example of what you are talking about?Use them on all Axis but with the Z axis mount the rails on the front plate and bearings on the rear plate, this will give the maximum strength when the Z axis is extended.
Does anyone have any pics of a similar setup?Another option and something I like and know Jonathan likes to use is connecting the motors to the screws via a short timing belt.
On another note regarding the Stepper/Ballscrew on both sides of the X-Axis, what happens when 1 stepper falls behind or fails?
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM -
BUILD LOG: Newbie First Build 3000mm x 1500mm
By psiron in forum DIY Router Build LogsReplies: 16Last Post: 16-07-2010, 11:02 AM -
By Dr Snuggles in forum DIY Router Build LogsReplies: 0Last Post: 10-01-2010, 07:05 PM -
NEW MEMBER: Hi, from a newbie #2
By colonelrichard in forum New Member IntroductionsReplies: 2Last Post: 04-08-2009, 03:02 AM -
By derekm in forum New Member IntroductionsReplies: 2Last Post: 03-08-2009, 06:45 PM
